Results 1 to 7 of 7
Thread: How much full sun needed to keep pool comfortable.
    Jun 2015
    Eastern Pennsylvania
    8
    I live in Eastern PA. We have only one suitable spot for our pool, but it is in almost full shade until about Noon and then pretty much full sun the rest of the day. How big of an issue do you think this will cause us as far as keeping the pool at comfortable temperature? If we use one of those solar fish invisible covers at night, would that be enough?
    The pool will be going in this part of the yard, pretty much in the middle green space just 'above' the patio pictured. This photo was taken at noon on May 30th, but that is basically what it looked like around 11:00 today, June 8th. By Noon today it was almost in full sun.
    15K Gal, IG concrete, variable speed pentair pump.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: How much full sun needed to keep pool comfortable.
    One season will answer your question as to if you'll need a heater or not...........or at least solar panels.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    inground pool? I think you are going to need a heater based on the short season. I lived in Maryland and had an inground pool with almost full sun and I found it stayed really cold until the end of the summer.
    EDIT: I see you are putting in an inground pool. I would budget the heater.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Do you own the property to the left? If so, you could take down some trees and that would help...but based on what Dan said you may want a heater either way. I guess it depends on what you consider "comfortable".
    Jun 2015
    8
    Yes, that is our property, at least a few trees deep is ours. I don't want to take down more trees, but I can if it seems to be needed. I don't think Dan and I have the same idea of comfortable, I find pools around here that are in full sun all day to get way too warm. 72-75 degrees is perfect to me. To rephrase my initial question: Does morning or afternoon sun have a stronger warming effect on a pool. The plaster will be dark .
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    afternoon sun/temps are higher than in the morning so they help warm it more. the issue is temperatures at night lowering the water temp, along with the fact inground pools stay cooler. if it was an above ground pool I think you would be fine. just not a lot of warming with that much cover.
    only you can determine if you are comfortable, whatever that temperature is. but the season is so short up there, I would hate to be waiting till July to get in a pool. build the pool and if its too cold, but a heater in next year. they are easy enough to add in after the fact.
    Dan
    May 2015
    Baltimore, MD
    7
    You will be battling leaves most of the season.
