Results 1 to 7 of 7
Thread: What is the correct TA for my pool?
    Jul 2014
    Oklahoma City
    6
    I have an above ground, vinyl liner, chlorine. 27000 gal. My pool store says 100-120. Is a TA of 90 a good place to stay for the summer? Or should I raise it to 100 or more?
    Thanks for your help!!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: What is the correct TA for my pool?
    Are you having problems with your pH moving or do you have to deal with high CH fill water? If not, don't worry about it.
    Jun 2014
    15,292
    The TFP Recommended Level chart (link below) says for your pool it should be around the 70-90+ range. 90 should be just fine unless you are experiencing any odd issues as JohnT asked above.
    Jul 2014
    Oklahoma City
    6
    No odd issues. Just opened it for he summer and it is at 90.
    By the way. You guys saved my "Hatred of my pool" last summer.
    Jun 2014
    15,292
    Glad to help.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Was that TA reading from the pool store, too?
    You don't think they were just trying to sell you some Alkalinity Increaser for $14/5 lbs which is chemically identical to Baking Soda in the grocery store for 80/lb do you?
    Jul 2014
    Oklahoma City
    6
    I learned my lesson last year. Pool stores no longer test my water or give me advice.
