Results 1 to 7 of 7
Thread: If CYA is between 30 & 40 so maybe 35?
    Jul 2014
    NJ
    46
    Since my CYA is between 30 & 40, I have been keeping my target Chlorine at 5. BUT then it seems to need chlorine every other day, chlorine will go down till about a 3 on the second day. Is there any problem doing it this way? I check the chlorine ever day, so I am not going lower. So just wanted to make sure that it is ok to "aim high" with the chlorine.
    5,700 gallon, Carribean Isle 15x52 Round Above Pool.
    Cartridge Filter.
    Installed Fall, 2014.
    North New Jersey
    Using the TF100 test
    30,431
    Re: If CYA is between 30 & 40 so maybe 35?
    You are doing that perfectly. You could not be more tuned in to TFPC.
    My bet is your water looks great??
    Apr 2015
    South Central PA
    298
    I'm in the same situation- I assume CYA=40, and add chlorine every evening to reach FC=6 (even is FC=4.5, as it usually does), so I never get near the 3 minimum....I may be a little aggressive by targeting higher...
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    30,431
    No, you are not being too aggressive.....either of you. It is FAR FAR worse to allow your FC to continually dip below the mins TFP has set.
    Donldson's Avatar
    NW Ohio
    2,916
    I can't really improve on Dave's advice. I only want to add that you should always round up your CYA measurement to the 10s. Even if it goes almost all the way up to 30, if it doesn't hit the 30 line call your CYA 40. As Dave said, there is far more risk from running low than running a little high.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    CYA isn't that accurate of a test, so to try and figure out between the two is just trying to apply more precision than available. just round up to 40 and base your FC on that.
    I keep my FC a little above the target amount, a few ppm isn't going to hurt anything
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jul 2014
    NJ
    46
    Great thanks! Yes my water is crystal clear, and everyone is asking me, because I a first time pool owner if I am having trouble, told them all about TFP and I think I may have "recruited" a few people.. LOL
    Cartridge Filter.
    North New Jersey
