Thread: Caretaker 99 distributor valve not working
    Jun 2015
    Phoenix, AZ
    1
    Post Caretaker 99 distributor valve not working
    I have a Caretaker 99 8-port system with 26 pop-up heads. About 1/3 of the heads are newly replaced and the remainder are in working condition. Pressure at the filter runs at 30 psi on a clean filter. Pressure at the Caretaker distributor runs about 15 psi when it is working properly.
    The problem is that the distributor valve is not cycling the way it should. I don't know whether the issue is mechanical with the motor and / or gearing, or if it is in the control circuitry. Can you suggest a troubleshooting sequence that will help me diagnose the problem and maybe avoid having to call a repair service?
    I am a new member on the site. I had this pool built in 2003 and have done the routine maintenance and pool care myself since construction.
    Thank you.
    In ground 25000 gallons, 15' X 50', pebble, Caretaker 99 8 valve, 3 hp pump, 7 c.f. sand filter, solar heat, auxiliary dual-mode heat pump, salt chlorine generator, safety cover, constructed March 2003
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Caretaker 99 distributor valve not working
    Welcome to the forum.
    I cannot, but there may be others who can. Good luck, and enjoy the forum.
    Essential Links:
