Thread: Going from Summer Escape RP600 to Intex Sand Pump/Filter
    Jun 2015
    Sugar Land
    1
    Hi All -
    Newbie here . Have been reading forums with lots of interest and believe I've picked up the relevant info but want to confirm here.
    Basically I have a Summer Escapes Freestanding/Easy Set (not pro series) 12' x 30" pool. Like most others I've found that the included RP600 pump/filter system is woefully inadequate. Therefore I want to upgrade to something like an Intex Krystal Clear Sand Filter pump either 1200gph or 2100gph.
    This SE pool does not have the skimmer setup - it has the suction fitting / thru wall intake.
    So my main question - can I change from the RP600 to this Intex Sand Filter setup? I want to avoid hole cutting and I believe I just need hose adapter fittings - I see some people keep the original filter/pump in place (obviously not using it) to avoid some connection problems?
    Thanks in advance,
    Darren
    Houston, TX
    38,548
    Re: Going from Summer Escape RP600 to Intex Sand Pump/Filter
    Welcome to TFP!!!
    Sorry you have not gotten any quicker responses.
    I am not familiar with the various systems on these pools. I am sure you can use an Intex pump/filter with that pool, but I am not sure if you can do so with cutting. Maybe someone else can help.
    dsilchenstedt's Avatar
    May 2015
    Rockport tx
    62
    Not sure exactly what you are trying to do but I chose to cut and not adapt. People go either way but if you have the tools I suggest cutting. The link in my signature has a lot of help full info. A lot of youtube videos for cutting and adapting exist but I only have the links saved for the method I chose. Hope this helps a little
    youtube:
    How to convert a summer escapes pro-series pool to larger intex 2500 gal pump - YouTube
    Converting the Summer Escapes Pool Filter to Intex Filteration - YouTube
    Round Frame Pool 15' x 42" (app. 3800 gallons) converted to Krystal Clear 2800 GPH .75 HP (conversion thread Here all the links/info you will need are within), TF100 Test Kit with speed stirrer. My first SLAM
