Results 1 to 14 of 14
Thread: Done with SLAM now need some help with maintenance....
    May 2015
    Springfield, IL
    50
    We got the pool done with the SLAM process last week but not exactly sure what we need to do for maintaining levels. So far, CYA and alkalinity and pH seem pretty stable but chlorine is still needing daily additions of bleach.
    Last evening my FC was 2 and CC was 0. Added recommended amount of bleach per pool math. We then got about 2"of rain to complicate things...
    Today's numbers
    FC 5.5 (not up to our goal of 6 but assuming that is due to the rain?)
    CC 0.5
    TA 100
    CYA 45
    pH 7.5 + (I'm not the greatest at estimating the color but it's at least 7.5)
    How often should I expect to have to add bleach? Our pool gets sun from morning until about 4pm when it is then shaded the rest of the day. We seem to be dropping to that low level of 1.5-2 every evening.
    27ftx4ft above ground pool with sand filter(brand new 2015) and 1.5hp hayward pump, TOTAL newbie to pool ownership (came with the house)...new TF-100 test kit in hand and ready to go TFP!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: Done with SLAM now need some help with maintenance....
    Bleach is a daily thing. What is your current CYA? Now that the SLAM is done, you should get it to 40-50 range. Then keep a close eye on consumption. You want to target the FC so that it doesn't dip below the minimum for your CYA before you add the next time. In a week or so, you'll have a pretty good idea what the pool's appetite is.
    May 2015
    Springfield, IL
    50
    Ooops... CYA is 45. Added to original post.
    Richard320's Avatar
    Jan 2010
    19,034
    Quote Originally Posted by Kimnlogan View Post
    That makes it easy, then. Your minimum is 4 FC. Target 7. If you find 4.5 the next day, perfect! If you find 5, target 6.5 the next time. Just whatever it takes to stay above 4.
    May 2015
    Springfield, IL
    50
    Ok...great, thanks! Should I expect to have to add daily?
    Richard320's Avatar
    Jan 2010
    19,034
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I tend to be a little looser with adding bleach when I am not around or not swimming. The rules I follow with chlorine in my pool is to never let the chlorine level drop below the minimum level for the CYA level. But, it is fine to go up to the shock level to make sure that chlorine stays above minimum if you can't add for a couple of days. You will get a pretty good feel for your usual chlorine consumption after a period of time and taking some notes to see patterns.
    It is also noteworthy that it is safe to swim when the chlorine level is above the minimum and below shock level for your CYA level. Here is the all important Pool School - Chlorine / CYA Chart
    May 2015
    Springfield, IL
    50
    Thanks all... going to take a while to get used to. Don 't mind tending to it daily.. just wasn't sure if I should expect to actually need to ADD bleach daily. I guess this is why the chlorine feeders became popular at some point... plop the tabs in and let them sit.
    May 2015
    Springfield, IL
    50
    Ok... so here is where we are... we keep having chlorine drop quite a bit so I added what I had last night (not enough for shock level but to boost it up)
    Last evening...
    FC 12.5
    CC 0
    This morning....
    FC 12.5
    CC 0
    This evening...
    FC 4
    CC 0.5
    TA 80 (this has dropped from 100 three days ago)
    pH 7.5 (nice and stable)
    CYA 35 (this has dropped from 45 three days ago)
    ????Thoughts... (I guess with the new CYA of 35 the FC of 4 is fine since it's the low limit but why such a huge drop in 12 hours??)
    May 2015
    Springfield, IL
    50
    Last evening...
    FC 12.5
    CC 0
    This morning....
    FC 12.5
    CC 0
    This evening...
    FC 4
    CC 0.5
    Anyone???
    Richard320's Avatar
    Jan 2010
    19,034
    Last evening...
    FC 12.5
    CC 0
    This morning....
    FC 12.5
    CC 0
    This evening...
    FC 4
    CC 0.5
    You lose percentages of FC to sunlight, not a fixed amount per hour. Higher FC levels means it disappears faster, which is why you can't just dump in a week's worth of bleach once a week. Lower CYA levels means it gets attacked by sunlight worse.
    Here''s a graph stolen from Pool Water Chemistry
    At 35 CYA and 10 FC you can expect to see a loss of about .8 FC/ hr. So if it was 10 hours between tests, it's nothing to be alarmed by.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Anyone???
    That is an awfully big drop for one day.
    Is the pool clear and sparkling?? With a big drop like that and a CC reading of .5 you may have algae still.
    The CYA won't drop that much but variations in your reading are normal. I would go with a number of 40 if i had readings of 45 and 35. Make sure you never go below the minimum for 40.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    May 2015
    Springfield, IL
    50
    So I can assume since I had no chlorine loss overnight that it's mostly sun and bather load then, correct?
    Oh and ETA: this morning FC was 4 again with a CC of 0.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Yes that is what you can assume. Just add bleach as needed to keep FC at target level or even 1-2 ppm above target level. I keep mine 2 ppm above my target level, so I don't have to worry if my SWG stops working.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
