Results 1 to 11 of 11
Thread: Spa Chemicals
    Jun 2014
    Monterey Tn
    38
    Spa Chemicals
    I just tested the water in my spa and if I read correctly all you test is the CH-PH-TA. (not sure if I read right)
    Anyway here are my readings
    Ch 10 should be 100
    PH 7.6 anywhere between 7.4/7.6
    Ta 40 should be 50
    I did try to check the FC but I get nothing, the water is clear, does not turn color at all. What am I doing wrong. We have Sanitized the Pool and thought I was doing good.
    19300 gal (27x54), AG, 22"Millenium Ultimate Granular Filtration w/2HP 2SP Pump,
    July 2013, Polaris 65 Vac, Confer AG Curve Step System, Taylor K-2006 Test Kit, Nordic Sport Hot Tub 300 gal, 78.5"R X35"D
    38,370
    Re: Spa Chemicals
    What are you testing with?
    Jun 2014
    Monterey Tn
    38
    Re: Spa Chemicals
    Taylor K-2006 test kit
    38,370
    Re: Spa Chemicals
    What is your CYA?
    How are you chlorinating?
    The low CH could result in some foaming in the water (you must have very soft water)
    Jun 2014
    Monterey Tn
    38
    Re: Spa Chemicals
    I will check again now and repost the results.
    Jun 2014
    Monterey Tn
    38
    Re: Spa Chemicals
    ok had to put some chlorine in the spa, i turn the jets on the pour in some chlorine.
    So do I check everything just like I would for the pool.
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Re: Spa Chemicals
    Just a side note. Water in your spa won't turn green because no light enters the spa.
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Jun 2014
    Monterey Tn
    38
    Re: Spa Chemicals
    just checked the spa here is what I came up with, not really sure if I test it just like a pool or not
    FC 4.0
    PH 7.0
    TA 40
    CH 10
    CC 0.6
    CYA BLACK DOT NEVER GOES AWAY ON BOTTOM OF TESTER
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Spa Chemicals
    Yes, you can test it with your pool test stuff. Maintenance is a little different. Here is a link to how I have maintained my hot tub for the 18 months that I have had it. I am very happy with this method. I don't actually do the dichlor part, I just add CYA and go straight to bleach because I have CYA and I don't have any pucks. You need to add CYA and get a borate test so you can test and add borates.
    How do I use Chlorine in my Spa (or pool)?
    Jun 2014
    Monterey Tn
    38
    Re: Spa Chemicals
    wow I am just not sure that I can do this. Its hard enough with the pool now trying to figure out the spa too, just don't know. If I am reading right I am just to check the CH-PH AND TA in the spa but I don't understand the CYA. Getting to old to figure this out, sorry to be so much trouble to you all. MY brain has just about given up on me.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Spa Chemicals
    The CYA target for the spa is around 30-40 ppm. You can either add that with pure CYA after a refill of spa water or you can start out using Dichlor until you build up to that CYA level (after cumulatively adding around 33-44 ppm FC) and then switch to using bleach.
    The spa is more work initially to set up after a refill, but after that it's pretty simple just adding chlorine after each soak and if you don't soak every day or two then in between soaks as well.
