Thread: Separate Pump for features
    May 2015
    keller
    129
    Hello all. I am considering running a separate Pump for water features in my new build and want your thoughts.
    15k gallon pool
    3 3ft sheer decent
    3 bubblers
    I want to have the ability to control sheer decent and bubblers independently of each other via easytouch.
    Should I run one massive 3hp vs intelliflo or two separate pumps? If I run two, what kind should I use?
    My energy rates are about 10 cents/kw
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Separate Pump for features
    Personally I would definitely run separate pumps. I can't make an educated suggestion on which pump to run...but a VS would be nice (adjustability in flow would be perfect to dial in the effect you want. my PB used a single speed pump for my waterfalls, and put a valve in it to alter flow characteristics....the sheer descents shot out 3 ft un obstructed. I suggested a smaller pump...he took another route (I don't agree with it, but I'll end up replacing with a VS when it craps out.)
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I am a big fan of my 3hp VS pump. It runs everything in my pool. Waterfall, skimmers, drain, solar panels all flow controlled by valves.
    Here is a newer, smaller Pentax VS pump
    Pentair SuperFlo VS Pump 342001 | Pentair 342001
    May 2015
    keller
    129
    I don't think the 3hp intelliflo will push everything at the same time. 3 bubblers amd 3 3ft sheer decents. Collectively that would need 150 gpm
