Thread: Sand filter PSI dropped from ~22 to ~8 during SLAM?
    Mar 2015
    Gainesville,FL
    5
    I am in the middle of a SLAM. The PSI gauge on my Hayward sand filter has been slowly creeping up over the last few weeks, and even after a backwash does not go down. And it doesnt go down when the pump is off either, so I figure its either broken or malfunctioning. However, I went out yesterday to brush the pool and add bleach, and saw that the PSI was 8. It had been around 22 earlier in the day. Since the gauge is suspect, Im not sure whats really going on. However, I went and checked the flow at the return jets into the pool and they are definitely flowing stronger than normal.
    So now Im wondering if somehow the filter is somehow being bypassed since the pressure is so low. Is this possible? The selector is in the normal 'Filter' position. Can a Hayward sand filter malfunction in this way?
    One more piece of info, I added about a cup of DE mixed with water to the skimmer the day before this to help clean up the water during the SLAM.
    I ordered a new glycerine filled PSI gauge from tf, but dont have it yet.
    Thanks for any help!
    18,000 Gallon in ground pool with SWG
    Plaster surface, Maytronics Z5 robot
    Multi speed pump, Hayward sand filter
    TF-100 test kit
    K-1766 salt test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Sand filter PSI dropped from ~22 to ~8 during SLAM?
    I would wait for the pressure gauge and go from there. The readings from your broken gauge are as suspect as test strips and pool store test results!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Your spider gasket might have torn which is allowing water to bypass the filter (low pressure in tank) and return directly to the pool (higher flow)
