Results 1 to 16 of 16
Thread: DIY Home Improvement Gurus?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Anyone here experienced with installing a prefinished hardwood floor? Looking for advice and survivor stories.
    We begin tomorrow, wish me luck....
    By the time my to-do list is complete, I won't want to move.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Re: DIY Home Improvement Gurus?
    What type of installation will it be? Floating floor or glued/nailed down. Have you let the wood acclimate to it's new environment for at least 48 hours?
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    11,969
    We're going to nail/staple it, renting a stapler. Over our existing vinyl floor...
    We bought the floor on Sunday, it's been sitting in the room next to the kitchen since Sunday night, in the boxes.
    DaveNJ's Avatar
    Toms River, NJ
    520
    Remove range, dishwasher to floor under them. Measure well to get as not to have a narrow boards at the finish end. Work out of a few boxs at a time. Stagger the joints by at least 6" and keep checking field as you go. You don't want seams to line a board or two apart. Check each board before installing. I set each board, tapped in place for a tight fit in both directions, length and butt end. Stand on the field and board your nailing (stradle nailer). This keeps it pushed down when nailing. You have to start the job and end off with finish nails. The nailer won't work for the first and last foot or so (wall interfernce).
    Did an addition kitchen, dining room in hardwood. Just finished 800sf laminate/interlocking.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    We installed prefinished wood strips (Bruce, 2 1/4") in our home in Louisiana. We glued the strips directly to the slab.
    I looked through all the boxes and fount the pieces I thought were 'interesting' and made sure those were placed in around in areas that would be visible, not under the dining room table or china hutch. I was also VERY particular about getting the joints staggered. The end result was lovely!
    Have fun!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I would also recommend to leave a 1/4" gap between the flooring and walls for expansion. This will be covered with base shoe to hide the gap.
    11,969
    Thanks all for the advice. I'll post before and after shots when I'm done!
    11,969
    Okay Before...
    11,969
    And After....
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Looks nice, but your mop is staring at you in the second picture :P
    DaveNJ's Avatar
    Toms River, NJ
    520
    Very nice work. Did you put felt pads on the chair legs. The felt does attract dog hair, dust, sand. I clean them periodicall and replace after a few years of use.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Wow, what coincidence! I'm doing mine right now, 800 Sq Ft!! That looks GREAT!
    Note its still dirty and no trim.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    yikes, I think I need to clean my camera lens.
    11,969
    Your flooring looks so similar. We did Columbia Taylor Honey Oak. Scratched it the first night moving the fridge back into place. Lovely. And the stupid chair pads keep falling off. Going to try a different brand. Now the cabinets look even more dated than before. You do one thing it makes the rest look icky, before you know it, it's a full remodel. I think we're going to paint them and get a new sink and countertops. That should help.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    I located a technique to refinish existing countertops, I'll let you know how it turns out. That flooring is Butterscotch Oak by Paramount.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by JohnT
    I thought that was a duster
    Your floor looks great!
    You're done SLAMing when:
