Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 91
Thread: Getting Ready for a good old fashioned SLAM
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    Hi everyone. I am getting ready for a SLAM and have a question about my Chlorine SLAM level.
    My #'s:
    FC 1.5
    CC 1
    CYA 30
    PH 7.3
    TA 100
    CH 175
    HCL 3600
    http://www.troublefreepool.com/conte...art-slam-shock
    Shows SLAM level for SWG pools at 28 and 31 for CYA levels of 70 and 80. "not recomended" at CYA of 60 (or below I would assume). My CYA is at 30 and everyone has been telling me to go ahead and SLAM with CYA at that level so I will not require as much Chlorine. So, since CYA of 30 is not shown on the SWG chart, do I use the SLAM level of 12 fromthe "Non-SWG" chart?
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    Jun 2014
    15,153
    Re: Getting Ready for a good old fashioned SLAM
    That's correct. Do it now at 30 and then after the SLAM you can let your SWG kick-in and pick things back up to normal. For now, just rely on the liquid bleach.
    During SLAM, most SWG users turn their system down while using primarily bleach to save on the SWG/cells.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    ^^ What Texas Splash said!
    Jun 2015
    Charlotte NC
    225
    10-4. Just wanted to be sure. Thanks for the reply.
    Ant
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Use the bleach chart, since you're using bleach.
    Is the pool a gooey green or black mess? If so, we want pictures! Daily updates. Vicarious thrills.
    Jun 2015
    Charlotte NC
    225
    It doesn't look THAT bad. It's a bit cloudy with a slight green tint. It's a brand new pool and I waited until it was full before adding salt, CYA, and turning on the SWG. I think my FC's were too low in the beggining and the algae is just now starting. I'll definately post some pics. Probably going to start the SLAM tomorrow. I work full time, so i'll have to do my SLAMing/testing before and after work. Twice a day should be OK right? Or should I SLAM and test before work, after work, and before bed?
    Ant
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by aboykin2269 View Post
    Start tonight, then the sun won't steal any of the bleach. It can all go to algae killing. The more often you check and replenish the bleach, the faster it goes. Lots of working stuffs hit it in the morning, then as soon as they get home, and again before bed. In your case, you could leave the SWG on to maintain FC while you're at work. It won't generate enough fast enough to get to shock level, but it should keep it from completely disappearing during the day.
    Jun 2015
    Charlotte NC
    225
    Should I be worried about damaging the cell?
    Ant
    Richard320's Avatar
    Jan 2010
    19,009
    Don't set it on boost. Set it for some middle ground, 40-50%. Yes, you'll be shortening it's life, but it started to die the first time you turned it on. You don;t have to turn it on, but would you rather come home to 10 FC or 2 FC?
    Jun 2015
    Charlotte NC
    225
    Ha! Yes I see your point. I would rather see 10 when I get home. This site is the best. Thanks for the advice. I'll keep my progress posted here (with some pics of course).
    Ant
    Jun 2015
    Charlotte NC
    225
    And we're SLAMin'!
    #'s from yesterday 6-08-15 (pre-SLAM):
    6:30pm
    FC 1.5 (GOAL 12+)
    CC 1
    PH 7.3
    TA 100
    CYA 30
    After initial SLAM (ADDED 3 QUARTS OF 8.25% LIQUID BLEACH)
    7:15PM
    FC 18
    CC 1
    9:40PM
    FC 16
    CC 1.5
    This Morning 6-09-15:
    4:25AM
    FC 11
    CC 2
    5:00AM
    FC 14
    CC 2
    pics from pre-SLAM:
    Ant
    Jun 2015
    Charlotte NC
    225
    Do I need to check the FC levels both before and after adding recommended bleach every time? Or can I check it, add what's needed according to poolmath and let it go until the next reading? I'm checking it first thing in the AM, as soon as I get home from work, and before bed.
    Ant
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    This one will not take long at all!
    For the first couple of times I would test before and after to make sure you are adding enough. After that just check before you add and use Pool math to tell you how much to add.
    Kim
    Jun 2014
    15,153
    You're doing well! Remember to keep running your pump 24/7. Remove any “muck” and debris, scrub all parts of your pool (including the ladder) to expose any algae, and vacuum/clean (or backwash) filter as necessary. You may have to do this several times. It's a lot of babysitting, but with patience and consistency, you will succeed. Remember ... "MAINTAIN" the SLAM (FC Level) until:
    1. Water is clear
    2. You do not lose any more than 1ppm of FC overnight (that's the OCLT)
    3. CC (Combined Chlorine) is <.5
    Good luck!
    Jun 2015
    Charlotte NC
    225
    Thanks Kim. I have read MANY threads on this subject and I have seen you post many encouraging and helpful replies. I LOVE this site. I never knew I could learn this much about water chemistry. I'm becoming OBSESSED with the TFPC method. I can't wait for a sparking clean pool!
    I'm all over it Texas Splash. The "M" in SLAM=MAINTAIN!
    Ant
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    I would get that ladder out of the pool during the SLAM and clean it up good, could be algae underneath
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2015
    Charlotte NC
    225
    Quote Originally Posted by DaninFLA View Post
    Thought about that too. Going to pull it this afternoon when I get home.
    Ant
    Jul 2012
    Tallahassee, FL
    30,525
    I bought my test kit BEFORE I bought my pool! I wanted to make sure I could do it before I committed to another pool.
    I was so pool stored with my last pool that it ruined my liner and I gave up and gave the walls and stuff away after the liner gave way and almost took me with it.
    My husband really missed the pool so I told him IF he could find a way for me to take care of the pool that did NOT involve the pool store we could try it again. Well he found TFP and we now have a pool we BOTH love!
    Kim
    Jun 2015
    Charlotte NC
    225
    Right on Kim!
    Well something is hungry in there (I'm sure we lost a lot due to full sun most of the day) but a check @ 7:45 pm shows FC @ 6! So I just added 2 quarts 8 Oz of bleach and will test again in 30-45 minutes after it mixes. I took the ladder out (my Honey is gonna scrub that down tomorrow) and I vacuumed. Gonna scrub the sides tomorrow and vacuum again. I'll post more numbers in a few when I retest. Thanks again for all the help Y'all are the BEST!
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    19,009
    You're SLAMming because of this?
    Why, I've stayed at hotels that had cloudier pools than that!
    I ratted them out to the health department, too.
