Results 1 to 12 of 12
Thread: Cloudy water going on three weeks!!!
    mamorton's Avatar
    Jun 2015
    Groton, New York
    4
    Unhappy Cloudy water going on three weeks!!!
    I had my pool installed last summer, but it took us most of the summer to get the electric installed.
    Therefore, the pool was never opened.
    When I opened it this spring it was a swamp.
    I have been shocking the pool and trying to keep the chlorine level steady since then.
    I did buy one of the Taylor test kits last week.
    The pool has never gotten clear. It is a hazy blue color and I can not see the bottom.
    Only can see down about a foot to a foot and a half.
    Here are some of my readings
    6/6/2015
    TC 0
    FC 1
    PH 7.4
    TA 150
    CH 220
    CYA 30
    6/7/2015
    TC 3
    FC 5
    PH 7.4
    TA 140
    CH 210
    CYA 30
    Shocked the pool between these two readings.
    We have been scrubbing and vacuuming like crazy. I do know there is still some stuff on the
    bottom of the pool.
    Any advice would be appreciated.
    Thank you
    18' x 33' x 52" Above Ground Pool, 1.5 hp pump with sand filter, vinyl liner
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Cloudy water going on three weeks!!!
    Welcome to TFP! Your numbers look good other than your FC is too low.
    What test kit are you using? You will need to have a recomended test kit to follow the SLAM process.
    To clear the cloudiness you need to SLAM.
    Pool School - SLAM - Shock Level And Maintain
    You will use pool math to determine how much bleach to add. You have to follow the SLAM until all 3 criteria are passed.
    Also keep brushing and vacuuming as well.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Your FC SLAM level is 12.
    If you can be at home to watch the pressure on your filter this will help too.
    Pool School - Add DE to a Sand Filter
    You will have to backwash when pressure rises 20-25% above clean.
    Lisa
    Jun 2014
    15,176
    Welcome to TFP! Please understand the TFP method does not simply "shock" or "super-chlorinate" a pool as typically advised by the local pool store. As Lisa advised, we do what's called "SLAM". SLAM is significantly different than an overnight “spike” in chlorine, and can take a few days (perhaps even a week or two) to properly complete. Be patient as SLAM is not an overnight process. Welcome, and post questions if you have them. Lots of folks here to assist.
    Apr 2015
    South Central PA
    297
    One thing I noticed - it doesn't help solve anything, but may help troubleshoot in the future- is your Total Chlorine can't be less than Free Chlorine (at least the way I understand it_..maybe your TC should be CC
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Good eye, 440dodge440! The formula is FC + CC = TC.
    mamorton's Avatar
    Jun 2015
    Groton, New York
    4
    Thank you. Will try to do this once it stops raining in my part of the world.
    I will also check my numbers again.
    Have a great day everyone. Raining again here.
    Jun 2014
    15,176
    Even though it's raining, don't stop on the SLAM you started! You must "Maintain" that high FC level until you pass the 3 SLAM requirements:
    1. Water is clear
    2. You do not lose any more than 1ppm of FC overnight (that's the OCLT)
    3. CC (Combined Chlorine) is <.5
    If you stop, slow down, or let that FC drop it voids all of your work so far. So stay at it!
    Also watch your CYA to ensure it doesn't drop below 30 or you will lose free (good) chlorine even faster. 30 for the SLAM is perfect, I'm just saying make sure it doesn't go lower.
    And say, while it's raining, take the opportunity to review the links you see in all of our signatures. The repetition will eventually become second-nature for you. Best of luck!
    mamorton's Avatar
    Jun 2015
    Groton, New York
    4
    Ok so I have been doing an actual slam for two days now. I had ordered the wrong taylor kit so I had to order the FAS/DPD (sp may be wrong) seperately, which finally arrived.
    New numbers:
    CYA 40
    Holding FC at 16 based on chart.
    Checking every two hours.
    Vacuumed and added 10 large boys to pool to get everything moving.
    Still not seeing much improvement. But am hoping this will happen soon.
    Thank you everyone for all the great information.
    Melanie
    Jun 2014
    15,176
    Sounds correct! Only two days into and it could take a little while more for all the dead algae starts to turn while, settle, and get picked-up by your filtration system. But yes, hang in there! You're doing what you need to be doing.
    mamorton's Avatar
    Jun 2015
    Groton, New York
    4
    Ok, so my pool is finally, after much vacuuming, scrubbing, and chlorine, beautifully clear. Just as a side note, my children are depressed because now they can not hide in it. No one is ever happy, but in this case mom is, so I win. I am going to attempt the over night test this weekend.
    I would just like to thank everyone for their help with this situation.
    Melanie
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Good news! Make sure FC is at least 10 for the oclt.
