Thread: Pressure Gauge- Any Recommendations?
    Apr 2015
    South Central PA
    298
    My pressure gauge works, but it moves kind of 'choppy' as pressure builds after turning on the pump. I think I'll replace it, or at least have an extra on hand. Many gauges I see are in the $3-$5 range, which seems very cheap considering what other parts sell for. I'm sure these are not top of the line, or even close though. Are there any specific brands of pressure gauges that I should loo for?
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Feb 2014
    Upstate, NY
    390
    Re: Pressure Gauge- Any Recommendations?
    Here is a very good one at an affordable price. Pressure Gauge
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    The gauges Dave has are really great. Most you see being sold in the $5 range are the standard air filled 60 PSI variety. The problem is that most pool plumbing never gets above 20, let alone 60. So you loose a lot of the fine detail you need.
    TFTestkits.net
    30 PSI & glycerin filled
    Support the site
    Apr 2015
    South Central PA
    298
    Thanks- I never thought to look here for the gauges....I'll tack one on next time I order reagents....
