Page 1 of 4 1234 LastLast
Results 1 to 20 of 79
Thread: Hayward Skimmer in Intex Ultra Frame AGP
    domct203's Avatar
    Jun 2015
    CT
    3,587
    I know that this has been covered here before, that's how I learned how to do it , but I wanted to share my through-wall skimmer install on my Intex 18' x 48" Ultra Frame AGP.
    It was really as easy as it looks, if you are at all considering it, just do it. Take your time, double check everything. I'll admit it, I was very hesitant to take a razor blade to my pool liner!!
    I used the Hayward SP1091LX skimmer as many here have had previous success with them.
    I drained the pool to about 1" below the skimmer location. I know that some have installed without draining, but I didn't want to take any chances, and the lawn needed some water anyway.
    I carefully split the butterfly gasket, then trimmed the leftover material from the split with a sharp razor. This needs to be done carefully.
    Next I placed the inside flange in its location, leveled it as best I could, and duct taped it in place. I took my Philips screwdriver (and a deep breath) and did this to my new pool:
    Be sure to support the liner with your fingers as you slowly push the screwdriver through the liner, turning it slowly as you push. I started with the top center hole, then the bottom center hole, then evenly around the outside putting a screw in each hole as I made them to keep the flange in place.
    I removed all the screws, then placed the inside gasket against the flange, and passed a screw thru the top center hole to keep the gasket in place. I then screwed the flange/gasket to the liner, putting the screw about 3/4 of the way thru leaving the gasket loose to line up the holes. I went around the flange installing all the screws about a 1/4 of the way thru, being careful to pass thru all the holes in the gasket.
    I then mounted the outside gasket over the screws sticking out, then carefully mounted the skimmer starting with the top center screw, then the bottom left & right screws, then the remaining screws evenly across. I went around the screws three or four times, tightening a little at a time evenly. When you finally tighten it down completely be careful you do not distort the flange and gasket. I tightened until I saw the gasket squish out very slightly then backed off until the squish went away. Sorry I didn't get any pics of these steps, I was a one man operation LOL!
    Here it is, right after I cut out the liner. You can see in this picture that even though I was very careful to level off the flange, somehow while I punched though the liner I slightly canted the frame. The skimmer seems to work just fine however.
    I cut the liner last, after all the plumbing to the skimmer was done.
    I hard plumbed the skimmer & original suction port using 1-1/2 PVC. I put ball valves for isolation and a union incase I should ever need to disassemble something. I plan to use the original port as a vacuum port now. I connected to the original Intex fitting using the 1-1/2 PVC electrical box adaptor as recommended here at TFP. I used the nut from an older plunger valve because I liked the fact that I could put it on after the cement dried. Also, if you are very careful you can use the gasket from the plunger valve as well, it's a close enough fit but a hair larger than the inside opening of the port. If you are persistent you can get it to stay in the port properly.
    I used a Game A2656 40MM X 1-1/2 Short Adapter for the Intex hose hookup.
    To keep water out of the original suction port (I was not draining that low) I used a 1-1/2" adapter and hose from an old Intex skimmer on the port & and lifted the other end of the hose out of the water. Worked great to keep the connections dry while the cement set. (LOL I just noticed the stick floating by, hence the skimmer install).
    On the Return port side I installed the 1-1/2" Hayward return that came with the skimmer. I though it would be best to have a standard fitting. It has a 3/4" eyeball, but I am going to change it to 1" to lower the filter pressure a bit.
    I then hard piped with 1-1/2" PVC and ball valve. I had to get creative with 45's as I ran out of 90's. I used the second 40MM adapter at the other end.
    Here it is, all hooked up and refilling while I let the cement dry good!
    Skimmer works great so far and no leaks!
    I hope this helps someone interested in doing this. It was super easy, just take your time. Once the pool was drained it only took me about 3 hours, and that's with double and triple checking everything.
    Next, solar heating !!
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2014
    Fountain Hills, AZ
    32
    Re: Hayward Skimmer in Intex Ultra Frame AGP
    Nice job! My husband installed a Hayward skimmer in our pool on Saturday and what an amazing difference it made! We were constantly scooping disgusting little bugs off the surface of our pool. It was a never ending job and I spent most of my time in the pool with the net in hand. I hate bugs! Three hours after he installed the skimmer, I could not find a single bug on the surface of the pool.
    Diana
    Intex AG 22' x 52" Ultra frame, Intex 2650 pump, sand filter and SWG
    Hayward in-wall skimmer, Wanda the Whale, center fountain, Intex magnetic light
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Nice job and thank you for sharing your pics. I am sure it will help someone!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2012
    Las Vegas, NV
    92
    for the Hayward return did you have to cut the liner?
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by latin_racer View Post
    I did. I followed this post. I am sure the OP did too.
    Adding a Hayward Thru-the-Wall Skimmer to Intex Metal Frame Pool (PICS!!
    Lisa
    Apr 2014
    FOUR cORNERS
    111
    Nice work, I did the same work, Skimmer, hard plumb,SWG, glad I did, it truly is TFP!!!!!!!!
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    domct203's Avatar
    Jun 2015
    CT
    3,587
    The Hayward return fit in the original return hole without cutting. It's actually a bit smaller than the Intex and fits the hole with room to spare.
    Dom
    Dom - TFP Guide
    May 2015
    Odense SŲ
    28
    Stupid Q: When the skimmer is placed where you did , can you then fill the pool to the top or should you leave it a bit lower than the top of the skimmer??
    domct203's Avatar
    Jun 2015
    CT
    3,587
    I found that my skimmer works best with the water about 2/3 the way up, or about 2" down from the top grey part of the liner.
    The skimmer needs to "skim" the top surface of the water.
    Dom
    Dom - TFP Guide
    Jun 2015
    Central NJ
    19
    Very nice work....I am jealous. I was wondering what rationale went into the placement of the skimmer? Most installs I have seen have the skimmer placed btween the original intex intake and return.
    Just trying to learn as I want to try this mod.
    Tx...Greg
    Intex 18 x 52 ultraframe
    1600 gph intex pump w 14" sand filter
    Hayward skimmer mod
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Dom,
    Why did you decide to split the butterfly gasket?
    I have just installed a new skimmer on a Doughboy, (the old one cracked) and other than trimming the lining a little (it stretched and interfered with proper gasket sitting, if it was split it would not) it actually helps so you do not need to hold two gaskets.
    (I had to use silicone caulk outside, as the surface pitted from age).
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    domct203's Avatar
    Jun 2015
    CT
    3,587
    Quote Originally Posted by morzh View Post
    Dom,
    I did not cut the liner until the skimmer was completely installed and plumbed, so splitting the gasket was necessary.
    My worry was that I might have caused a tear in the liner while cutting, from the weight of the water in the pool. With the skimmer installed and all screws tight I was much more comfortable cutting the liner.
    Dom
    Dom - TFP Guide
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    Thanks for all the helpful info and pics for your Hayward skimmer installation. Will pass this on to my hubby
    Intex Rectangular AG Ultra Frame Pool Set, 24' x 12' x 52" (8403 gal, well water)
    Intex Krystal Clear Saltwater System model number: 28663EG/54601EG
    Intex sand filter pump, 120V 1,600gph with GFCI
    Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer
    Jul 2015
    NY
    22
    Sorry to dig up an old thread. I'm curious if folks using a skimmer on the Intex AGPs are also using solar covers? Does the latter interfere with skimmer operation? I'd assume a solar cover would in any case help reduce the amount of bugs and other debris getting into the water, but I'm still curious. We just installed our AGP and it's mind boggling how many bugs see our pool as an open invitation to splash around and work on their swim strokes!
    Intex 16' x 48" Ultra AGP - 5100 Gallons
    Intex 2650GPH Sand filter + SWG (SKU: 28679EG)
    domct203's Avatar
    Jun 2015
    CT
    3,587
    A solar blanket will float on the surface thus eliminating any surface skimming as the surface is covered.
    I only use my solar blanket overnight & the bulk of my filtering is done during daylight hours.
    Dom
    Dom - TFP Guide
    Jul 2015
    NY
    22
    Thanks Dom. Excuse my ignorance, but do you lose some "heating" performance by having to take the solar cover off during the daytime? I initially thought that they were to help with warming up the water during the day, but when I think about it, the uncovered pool probably acts as a better greenhouse, and the solar cover is probably only useful at nights to help retain heat. Would that be correct?
    domct203's Avatar
    Jun 2015
    CT
    3,587
    IME I find that open during the day & covered at night gives me the best balance of heat retention & UV exposure. The pool needs to breathe & UV (sunlight) helps to break down CC's.
    Dom
    Dom - TFP Guide
    Jul 2015
    NY
    22
    Thanks Dom, that makes sense. I guess a skimmer may be on the cards at some point in the future. Not too keen on giving up a couple of inches of water level for the skimmer though. I'm 6'3", so every extra inch of water counts for me!
    Jul 2015
    Santucky, CA
    34
    Dom,
    Why did you leave the water out plumbed (aka input to the pump)?
    The clamp on my stock bucket skimmer just broke. I'm considering this addition.
    Costco Bestway AG Pool 9x18x4. (Installed July 2015) 4500 gallons
    Intex 2800 GPH Pump & Sand filter
    TF 100 Test Kit
    335 Gallon Jacuzzi
  20. Back To Top    #20
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Dom, Curious how tight you had to crank down the game adapters? I just got a new pump and I am using the adapters. My pump said to hand tighten and then 1/2 turn more. They are leaking and I used the teflon tape. Just wondering how tight you had to get the adapters? I don't want to break my pump or adapters. Thanks in advance.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
