Thread: 5 years with a Compupool cps-60
    I thought I would send a review of 5 years experience with this.
    The product actually works quite well, but and a big but.
    They leak, the cell leaks, the couplings leak. The sell housing leaks because
    it cracks. The cell housing is made of styrene which is very brittle and cracks
    very easily. I replaced the cell housing 5 times in 5 years. The plug on the back of the cell
    burned up and then the cell power pins started leaking. After all this I give up and
    removed it. The constant problem of leaks was just too much.
    I do miss not having to go to the store to get chlorine.
    Cliffs
    Jul 2014
    Peoria, IL
    389
    Re: 5 years with a Compupool cps-60
    I have a cpsc24 and have had zero issues with it for the last 3 years. Count myself lucky I guess.
    Mine needs to be cleaned about every 2-3 weeks due to scale building up so I assume the reverse polarity is not working or bs. But other than that I am all good.
    Do you have to clean your cell at all?? And if so are you using the "preferred method"?? As told to me by the pool store/compupool was to take the blue hard plastic housing apart into 2 pieces to brush off the grids. Doing so the first time I had to pull so hard I was afraid that I was going to break the housing. I now clean with water and a bit of MA poured into the housing as it is wedged into a 5 gallon bucket. Works flawlessly and may have prevented leaking issues for me.
    The melting plug issue I have seen but luckily not experienced.
    Sorry that you have had issues. Has compupool taken care of your issues or have the fixes been on your dime?
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Jun 2011
    Long Beach, CA
    2,788
    To prevent scale buildup you need to have the CSI in the negative range or else all cells will buildup scale even if the reverse polarity is working.
