Thread: Do water bugs mean algae?
    May 2015
    Omaha
    4
    Current test FC 7, cc 0, ch 280, ph 7.8, TA 130, ca 50
    Been through a slam 3 weeks ago. Since I have improved ca from 80 and TA from 250 to current. The lowest FC has been is 6.6. We missed a few days on brushing but not more than one day in arow. Pool is clear with only the rust stains I get from my well water on the floor and walls (getting better since opening). Today saw a large increase in water bugs. I believe backswimmers. Since slam there's been a few bugs with small increase then there would only be a few. Besides going through a slam are there any other suggestions? I've heard certain algecides or dish soap (don't know how soap effects a pools chemistry) are possible ways to kill existing ones.
    20k gal inground plaster pool with 2hp pump, sand filter, kreepy krawly,cleaner with chlorinator. Well water Full sun. Leslie's 81329 kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    8,734
    Re: Do water bugs mean algae?
    Algecides and soap are both things you do not want to introduce to your pool. No, they do not mean algae in the water.
    Support the site
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,840
    The presence of water bugs (e.g., backswimmers) is not related to algae. More likely, you've just hit the time of year where their populations increase. I occasionally get a couple in my pool and I have never had algae. You can try bumping FC up to the high end of the recommended range for your CYA and/or add some borates to the pool in the range of 30-50 ppm. Those measures may reduce the number of water bugs that get into the pool but don't be surprised if you get one or two from time to time.
    Casey's Avatar
    SW PA
    10,290
    I get a couple every year and have borates. They are not as noticeable now.
    May 2015
    Omaha
    4
    Thanks for the comments. I'll look into borates. Yesterday we had 100+ Bugs this morning it is well reduced. Maybe they were just passing thru and found no food source.
