Results 1 to 9 of 9
Thread: Test Kits/Strips
    Mar 2012
    Boerne, Texas
    20
    Test Kits/Strips
    Thanks in advance. There is continued confusion in my head when trying to wrap my head around the whole CYA testing!
    To confuse myself further, I used a test strip because I just don't feel comfortable with my CYA testing abilities…did I see the dot? is it really there? I think I still see it? Maybe I don't? UGH!!!!!!
    My test strip says my CYA is LOW but using my TF-100 kits it says it's 90 (I think). Really bothers me that there is such a big difference. Anyone know why this is? Are test strips truly worthless?
    Pool size = 16,000 gal, IG Fiberglass, 2 speed hayward pump with cartridge filter
    April's Avatar
    Apr 2014
    KY
    138
    Re: Test Kits/Strips
    Trust your TF-100 before the test strips.
    Are you doing the CYA test outside with your back to the sun?
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would not call test strips worthless, I would however call them one step better than a Ouji Board
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Did you watch the video of how to do it?
    Maybe this will help.
    Testing Cyanuric Acid with the TF-100 - YouTube
    Divin Dave,
    Donldson's Avatar
    NW Ohio
    2,881
    I like to say that test strips are great at measuring the distance to the bottom of the trash can, and I mean it.
    Just remember, the general opinion on the site regarding pool store tests and test strips is not without merit. The number of bad results from these methods over the years is staggering. You are doing fine, the CYA test is not the easiest. Watch the video Dave posted and remember you can pour it back and forth between bottle and tube to retry it a few times until you are more sure.
    You got this, if I can do it with my terrible eyesight, you can too!
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    My biggest problem with the test strips is that a given dot on the strip represents a range. For example, one I saw recently had a "Good" range of 30 - 50. That's very comforting and all, but it doesn't tell me whether it's 30 or 50 or somewhere in between. If that isn't bad enough, the next dot on the scale represented a reading of 100. So if my actual CYA is 70, where will that show up?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    CYA on a test strip is the least accurate. Really the only thing a 5 or 6 way test strip is good for is to show presence of chlorine and approximate pH. They measure total hardness so they are inaccurate for calcium levels.
    They are sensitive to humidity, temperature, and age. Unless they have been carefully cared for from factory to home a lot of factors can render them useless before they can be used.
    Love TFP? Become a
    TFP Supporter!
    When testing CYA using your TF100, wiggle the bottom of the test tube while you're pouring in the solution. Our eyes are better at seeing movement than seeing subtle shades of grey behind a reflective surface. The movement of the dot avoids the persistence of vision problem, and gives you more consistent results.
    I rest the top of the test tube against the squeeze bottle with the poolwater/reagent solution (so I don't lose any), and wiggle the base just enough to see the black dot move. When I no longer see movement, I take my reading.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    When I do CYA test with the TF-100 kit i get different results (20 then 35 then 30) using the instruction video. I keep doing it with the same sample 3 -4 times and just do an average from the test.
    Rick T.
    12,000 gallon IG Kidney shape,gunite,white plaster w/25% blue quartz (Chlorine)
    Jandy LED Multi-color pool light, ,Pentair VS Pump,Pentair FNS 48 DE Filter,Polaris 280 Cleaner
    TF-100 test kit, Taylor K-2006 test kit, Speed Stir, BBB Method, PoolMath, TFPC
