Thread: Help -- Sta Rite Heater on the fritz
    Jun 2015
    Littleton, MA
    3
    I have a 330K BTU LP Sta Rite pool heater. It is approximately 10 years old. It has not been working properly and I was looking for some ideas before I buy a new one.
    The following is a description of how it is behaving:
    Turn on breaker...display reads R-5 (I think a good thing)
    Yellow "HEATING" LED flashes
    Heater fires, but not very loudly - approximately half as loud as when it operated properly
    Heats for a few minutes and "Heating" LED flashes
    The heater stops firing and reignites with a loud swoosh sound
    I get a faint smell from the exhaust of unburned propane (not sure what the odor is)
    This cycle repeats constantly.
    Amy ideas to troubleshoot?
    Thanks
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Help -- Sta Rite Heater on the fritz
    Either the blower motor is going or the can is filled with water. Remove the bottom bolt on the header and see if water comes out. If so, you have a leak in the heat exchanger and best to replace the unit.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2015
    Littleton, MA
    3
    Thanks. Which is the bottom bolt on the header? I ran it for about one hour today and it kept doing the same thing. Cycling on and off and firing very weakly.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Do this first actually. Remove the thermal regulator and see if it's all gunked up. Also you can check and see if the bypass is in good shape by feeling for it just above the regulator.
    Go to this link and get the manual to help you locate the parts.
    http://www.google.com/url?sa=t&rct=j...95039771,d.b2w
    Paul
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    Remove the bolt first (its easier).
    Factory Warranty Station for:
    Jun 2015
    Littleton, MA
    3
    Thanks, guys.
    PS0303: I will check the thermal regulator tomorrow. Is the bottom bolt on the header the bottom bolt on the manifold? I cannot find anything labeled "header" on the diagram.
    I appreciate the help. I have the propane company coming to check the regulator and gas pressure on Monday.
