Results 1 to 8 of 8
Thread: Abandon or replace floor returns?
    Jul 2012
    Saugerties, NY
    447
    I have a customer that has an old concrete pool that they are thinking about renovating. Its in rough shape, but the owner is a mason, and can do the concrete work himself, which I think is going to be the hardest part. They brought me in to check out the plumbing and equipment before they sink lots of time and money into everything else.
    The pool has a lot of plumbing. There are two skimmers, a lower suction in the wall, a main drain, four returns, and eight floor returns. The pool is only roughly 18'x36'. I'll be pressure testing all of the plumbing in the near future, but I'm wondering if we will be able to find replacement return covers for the floor returns, or if the floor returns will even be necessary. Can they be abandoned and covered with concrete? Is it worth chipping away the concrete and replacing them with more modern and readily available fittings? My experience is mostly with Vinyl Liner pools, so I'm not sure what the best options would be with an old concrete pool.
    Any suggestions or ideas?
    TreeFiter
    Pool Technician
    Saugerties, NY
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,015
    Re: Abandon or replace floor returns?
    In almost all instances, "floor returns" are actually part of an in floor cleaning system. Is that what they are or are they actually returns?
    Returns in the floor do not make a lot of sense.
    the returns are supposed to be angled so as to provide a circular current on surface of the water and that circular current carries debris to the skimmer(s).
    Floor returns would be extremely disruptive to that.
    Divin Dave,
    Jul 2012
    Saugerties, NY
    447
    I don't think they are part of an in floor cleaning system. I'm familiar with systems like the caretaker, which usually have the big control head valve and various other components that are necessary for them to work.. I have seen several pools over the years with floor returns. I don't know why the builder wanted them there, but they are definitely returns. They look like a main drain, but usually about half the size.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    I did some research a while ago and discovered that for a while, it was fashionable to return heated water via the floor so the hot water would rise and warm the water above rather than just evaporate off the surface.
    You see any funky looking valves like this? It's a 4 port.
    More information on it. The Palmer Flowreversal Module - Pool Flowreversal Technology Not sure if you need special software to read that. Let me know.
    Jul 2012
    Saugerties, NY
    447
    No, there are no strange valves present. Much of the plumbing has been hacked out. There are just a bunch of pipes coming out of the ground at this point. I have gone through and identified which pipe goes where, and the floor returns are on their own pipe. In fact there are two pipes going to floor drains. The main drain has its own pipe, the two skimmers share a pipe, and the four (near surface) returns share one pipe.
    I've seen a handful of older concrete pools with floor drains, and I have a customer that just built their pool this season, and the builder installed floor returns for some reason. Oddly enough, I maintain two other pools from this same builder, but neither of them have floor returns. In the older pools, there are no other returns in the pool. Only the floor returns.
    So given that these floor returns are on their own plumbing, and the pool has a main drain and surface returns, what would be the harm in eliminating them? Is it worth the effort to fill them in with concrete and plaster over them? Or would it be better to cut out the fixtures and retrofit new ones. My big concern is that there aren't any grates to cover the holes. I can't imagine they will be easy to find. Its probably not a good idea to leave big holes open in the bottom of the pool like that.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Richard320's Avatar
    Jan 2010
    19,073
    I'd fill 'em in. You'll already have dual main drains to comply with Virginia Graeme Baker Act, right? That's enough. One is plenty. People have giant oval above ground pools that size and manage just fine without a drain.
    Jul 2012
    Saugerties, NY
    447
    I don't think there is a dual main drain. Its an older pool, so I'm assuming one. Can't see right now because the sump is full of nasty green water.
    I think you are right though. Just about every pool I work on does just fine with a skimmer, main drain, and a few surface returns. Some do just fine with significantly less. There are a few dinosaurs out there in really bad shape where we have put "temporary" lines above ground to keep them going, and they manage to stay reasonably clean.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,015
    I would fill in the floor returns. No real purpose in having them. Who knows... maybe way back when it was built, that was the fad for new pools!
    Divin Dave,
