Results 1 to 8 of 8
Thread: CH continues to rise...
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Hey there...some of you might remember the pool was a new construction and filled the week before Christmas this year...so just under six months...(and completely drained and refilled once due to a calcium scale build-up due to the PB not doing an acid wash on the new Stonescape application. I have a question...
    My CH was stable for a few months (in the 425 nieghborhood). The last few weeks it has been rising. Last Sunday it was 475. CH is now at 500 although CSI is at -0.03. The only thing I have added over the last few weeks is HCL, Bleach, Boric Acid (from Duda), and one 40lbs of solar salt.
    Question: Do you think this is happening due to the curing process or for some other reason?
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: CH continues to rise...
    It may be happening as a by-product of topping it off with fill water. Although water evaporates, calcium does not. If your fill water has a higher CH level than the water in the pool, your CH will gradually rise. It's probably worth your time to test your fill water's CH.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Good point that I failed to mention. No fill water has been added we get plenty of rain here in Central Florida. Only rain has been added in addition to the Boric Acid and solar salt.
    30,414
    After 6 months, I would assume your plaster would not throw off any calcium. That said, I can think of absolutely no other explanation.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    I must have had a bad test...it was at 475 today. Thanks for your help.
    Nov 2014
    Palm Desert, CA
    99
    Quote Originally Posted by BoDarville View Post
    BoDarville - I'm having rising CH too. My fill water is 100 and my CH for today was 450. You say if the fill water has a higher CH level than the water inside the pool, then CH will gradually rise. Does that mean with my numbers my rising CH is probably not due to the fill water? We replastered in January so maybe it is still just the calcium from the curing plaster? I was considering a water softener for my pool but I'm not sure. Sorry that I'm hijacking this thread.
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    That is not correct. Every gallon that evaporates leaves its calcium behind. Every gallon you replace adds an additional calcium to the pool which will cause the CH to slowly rise. If you drain water from the pool and replace it with fill water, then your CH will drop.
    You have a lot of evaporation and your CH rise is more than likely from the fill water.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by LisaDLu View Post
    The CH stays.
    Let's say for easy math that your pool is 50" deep and your CH is at 450. You lose 2" to evaporation. That's 4%, .04. Same CH in .96 as much water, so CH will read 450/.96 = 469 CH. If you refilled it with distilled water, it would go back down to 450. But you aren't. You're using water at 100 CH.
    So... (.96*469) + (.04*100) = 454
    You just need to know your average depth and you can figure out how much CH you add with every inch of refill water.
