Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: 27 round AG Pool Pump and Filter Question
    May 2015
    transfer/PA
    11
    I've been perusing the forums in search of what pump and filter I should use. I just recently bought a home and acquired a 27` round pool that is LOADED with leaves, but that is another thread all together. For now, I want to get this pump/filter purchase nailed down since somebody apparently stole the old setup. Here is what I know.
    Gallons - around 17k (well water)
    Run - The deck for the pump/filter is located directly next to the pool under a deck w/plenty of access. So maybe 2-3 feet.
    Setup - It is a standard AG setup with the skimmer located up high on the side of the pool.
    Also I will add that this pool is surrounded by nearby trees. It probably gets half a days worth of direct sunlight on a clear day.
    Please let me know if you need any more info.
    Here is what I am considering:
    SAND FILTER
    Hayward S244T Pro Series Sand Pool Filter 24" With Valve
    PUMP
    Hayward Max-Flo XL Pool Pump 3/4HP - SP2305X7
    I was trying to stick to a $1000 budget for getting this pool up and running, but after looking at the cost of these 2 items alone, I may have been a little too optimistic...or cheap. Thanks for any and all replies.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,505
    Re: 27 round AG Pool Pump and Filter Question
    I will just tell you what I have and works great for my 33' round pool:
    Clear Water Waterway sand filter 26" and a Waterway 1.5 hp variable speed pump.
    Kim
    May 2015
    transfer/PA
    11
    Thank you for your response. I'll look into both of those items. I just want to make sure that what I am looking at isn't overkill or simply the wrong type for my pool. I've read all the pool school info, but I'm afraid to make a decision until I hear from some veterans like yourself Kim. My test kit comes Thursday, so I'm hoping to get this part locked down so I can start testing, cleaning, and hopefully swimming!
    Jul 2012
    Tallahassee, FL
    30,505
    The filter cannot be overkill. The bigger the better! NO one has ever said "I wish I had a smaller filter". The pump........that is what came with my pool so that is what I use. It moves the water great. I have not had any problems with my pool since it was put up.
    Kim
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    and then you have guys like me I went overkill, But I am planning on going inground with the same setup in 5 to 10 years, and I have the ability to expand...
    this looks like a great little 2 speed 1hp pump for $211 8.8 amps on high and 2.6 amps on low
    Amazon.com : 1 HP 2-Speed 3450/1725 RPM, 115 volts Above Ground Pool Pump - Waterway brand - With large Debris Ba : Swimming And Pools : Patio, Lawn Garden
    and this looks like a good filter for $290
    Amazon.com : Hayward Pro Series 24 Inch In Ground Pool Sand Filter : Swimming Pool Sand Filters : Patio, Lawn Garden
    That puts you at 500 for filter and pump
    You would have to get the correct unions to fit the pump and filter and hard pipe it to the pool
    May 2015
    transfer/PA
    11
    Ok. I made a few adjustments hoping to save a little and still have an efficient setup. My TF-100 test kit came in the mail yesterday, so I am REALLY excited to get started on this pond. Thank you to everyone for your replies.
    Hayward S210T 21-inch Pro Series Sand Filter
    Hayward SP1591 Power Flo Matrix AG 3/4 HP Pump
    I'm really hoping these will do the trick!
    May 2015
    transfer/PA
    11
    Please let me know if I am on the right track before I purchase
    I recently purchased a home that came with a 27' round pool. It gets direct sun until about 2:30-3 daily. The pool is surrounded by trees. I've already purchased my TF-100 pool kit in preparation of getting this beauty blue again, which will be a long road. After reading through the forums, this is what I'm considering. Thanks for any and all help.
    Jun 2014
    15,121
    Re: Please let me know if I am on the right track before I purchase
    Welcome! You've done the single most important part already - ordering that TF-100. You will love it, and it will pay for itself. Really, until it comes in and you post some test results, there's not much we can do right now unless you have a specific question about your water condition or equipment. Since you mentioned "turning your water blue again", I'm assuming it's cloudy or green perhaps? If that's the case, please take a moment to read the two links below titled "SLAM" and "Chlorine/CYA Chart". Those are key pieces of information for you to follow.
    In the meantime, if you have any other questions, please let us know and we'll be glad to assist. Have a great day!
    Also, please don't forget to add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Welcome to TFP!
    Ok, while you wait for your awesome test kit get the leaf rake and scoop all the debris out of your pool. It will make the SLAM go much faster and use less chlorine/bleach.
    Have you read the SLAM process 4 or 5 times? Here it is, Pool School - SLAM - Shock Level And Maintain
    Jul 2012
    Tallahassee, FL
    30,505
    Hi! You are already so far ahead with the test kit you will do fine!
    Kim
    May 2015
    transfer/PA
    11
    Quote Originally Posted by Texas Splash View Post
    My question is:
    Is this pump and filter sufficient for my 27' round pool?
    But yes it is definitely full of leaves and amphibians. I got lucky and the pool did have a winter cover on it, so it did save me some work scooping leaves, but it had some holes in it, so I know that isn't where the story ends. I haven't taken the cover off yet, but I move in this week and plan on taking it off. I'll start another thread pertaining to cleaning the pool, but for now I wanted to make sure my equipment will be efficient. Thanks!
    May 2015
    transfer/PA
    11
    Quote Originally Posted by pooldv View Post
    Welcome to TFP!
    My test kit was the first thing I bought when we bought the house about 2 1/2 weeks ago haha, so it's already in my posession. I also did buy a leaf rake right away...actually bought 3 because the first one broke 5 minutes into using it. I haven't purchased ANY chemicals as of yet, but thats only because I'm still a few days maybe nights of scooping leaves and sticks out of the bottom of the pool.
    DFW, TX
    24,492
    Pump is ok, filter could be a little bigger.
    Sounds like you are all set to go!
    May 2015
    transfer/PA
    11
    Welcome to TFP!
    I will be reading this thoroughly while waiting for my pump/filter to arrive. Thanks! Also, I will jump up to the 300 lb filter to be on the safe side.
    Jun 2015
    Haughton, Louisiana
    50
    Mine was like yours when I started minus I had pump and filter. Stay the course when you start slamming. I had my doubts I'm day 13 in, but it will work goodluck
    24" Round Above Ground 14000 Gallons, Pentair Sand Dollar Filter, 1.5 HP Pump, K-2006 test kit
    May 2015
    transfer/PA
    11
    Another quick question about this topic. I've been looking for a 300 lb sand filter and everything I find says it's for in ground pools. Is this ok to use?
    May 2015
    transfer/PA
    11
    Anyone?
    Jul 2012
    Tallahassee, FL
    30,505
    No help here A bump for someone else to see-------Calling all filter experts please look
    Kim
    Apr 2013
    North OKC Area
    300
    Does the filter come with a pump? If so, the "in ground" is likely referring to the pump. It is fine to use an in ground pump on AGP, but not the other way around. I haven't seen a filter that can only be used on an IGP.
  20. Back To Top    #20
    May 2015
    transfer/PA
    11
    It does not come with a pump. It is stand alone on Amazon.
