Results 1 to 12 of 12
Thread: Green pool... Help please!
    Apr 2015
    Los Alamitos, ca
    5
    Question Green pool... Help please!
    Hello
    Thank you so much for your posting of problems/issues and the solutions.
    I'm using the Taylor 2006 test kit.
    My pool is 15,000 inground. Starite cartridge filter. Pentair intellipump variable speed. Solar heating panels with Suntouch controller.
    I am using liquid chlorine 12.5% and liquid acid from the local pool store.
    My pool has been been for couple weeks now and today it got worst.
    here are the test results from the last two days:
    6/6/15:
    FC = 8.5
    CC = 0
    PH = 7.8 - 8.0
    TA = 150
    CYA = 75
    6/7/15:
    FC = 5
    CC = 0
    PH = 8.0 - 8.4
    TA = 150
    CYA = 55
    Your help and suggestions are greatly appreciated.
    The Poolmath recommendation is to add 18 oz of washing soda or 39 oz of borax by volume, is this correct?? I thought to lower the pH to the proper level, i would need to add muriatic acid.
    Thank You
    Duke
    - 15,000 gallons in-ground pool. Starite cartridge filter, Pentair Inteliflow variable pump, solar heating with Suntouch controller.
    - Test kit - Taylor 2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Green pool... Help please!
    Welcome!
    Don't add anything just yet...
    How'd the CYA drop from 75 to 55 in one day? The only way possible is if you replaced 25% of the pool water. So there must be some kind of testing error. Not to worry; you're not the only one who has problems with that test. Repeat it as many times as necessary with that same sample until you're sure of what you're seeing. There are videos on youtube if anything seems unclear.
    Okay, second point, Soda Ash and Borax RAISE pH. Yours needs to come down. Better check for a typo in poolmath. Maybe you entered your target too high. It should be 7.2 target.
    Lastly, you need to perform the Shock Level And Maintain process to get rid of the green. To do that, you really need to know your CYA. You can do it. Don't go to the pool store and have them doublecheck. They'll probably get it wrong even worse than you.
    Some inspirational reading. Start with the last page and work backwards up the list for the most recent ones. If they can do it, you can do it.
    Jun 2014
    15,129
    Welcome Duke! You are off & rolling with a rock-solid test kit and some great advice already. Additional links are in my sig if you need them. Hope you find everything here useful and have a great summer.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    What Richard said.
    Divin Dave,
    Apr 2015
    Los Alamitos, ca
    5
    Last night I added half gallon of muriatic acid.
    Here's the new test data today
    FC 2.5
    CC 0
    PH 7.2 - 7.4
    TA 120
    CYA 70
    The recommended shock level from pool math is 28 ppm which is equivalent to 407 oz of liquid chlorine. Is this sound right. Should I start the SLAM process? The pump should be on 24/7 correct. Also does the pump speed (rpm) matter? Currently it's set to 2000 rpm.
    Thanks
    Richard320's Avatar
    Jan 2010
    19,004
    Quote Originally Posted by Dukduk007 View Post
    FC 2.5
    CC 0
    PH 7.2 - 7.4
    TA 120
    CYA 70
    Thanks
    Sounds right, depending on the strength of the bleach. Low speed is fine. You just want to keep it circulating all night.
    Apr 2015
    Los Alamitos, ca
    5
    Thanks Richard.
    The test result from this morning:
    FC 28
    PH 7.6 - 7.8
    TA 140
    Should i be concern about the pH and TA for now?
    Thanks
    May 2014
    Vienna, VA
    37
    Don't worry about the PH until after you're done with the SLAM -- the PH readings are inaccurate when FC is higher than 10.
    40K gallons, IG, plaster coated with AquaBRite, circa 1987, 60sqft Crystal Water DE filter, Hayward Ecostar VS pump, SWG, attached spa w/spillway, 2 skimmers.
    Apr 2015
    Los Alamitos, ca
    5
    Hello all..
    Thanks for all the great advises.
    My pool today is no longer GREEN but it's not crystal clear yet. The FC level seems to stabilize (no chlorine loss overnight)
    Questions:
    1. Should I continue to keep the FC at the shock level?
    2. when should I start testing for pH and TA to get it to normal range?
    3. I've been running the pump 24/7, should I continue?
    Thank you in advance.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    You are only done with SLAM when you pass ALL three criteria: 1. water crystal clear 2. overnight loss 1 or less. 3. CC < 0.5
    Maintain your shock level.
    pH testing is only accurate when FC is < 10. Don't worry about TA until the rest of your levels are balanced.
    Continue running your pump 24/7 until your SLAM is complete.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Apr 2015
    Los Alamitos, ca
    5
    Hi All
    The SLAM is complete. met all 3 conditions. Thank You very much.
    Since the FC is still above 10 and the pH is 7.8 - 8.0 TA is 120 and CYA is 70, I should wait for the FC to go below 10 before i can adjust the pH level? My CYA higher then the recommended level. In order to lower the TA, I have to partially drain the pool which I don't want to do due to the drought situation in CA. What are my options?
    Thanks
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Once your FC is below 10, then adjust pH. Your TA will come down over time as you maintain your pH. Each time your pH hits 7.8 or higher, drop the pH to 7.2. Every time you add acid, the TA will come down.
    Congrats on completing the SLAM!
    Isolated Spa - 345 Gallons
