Thread: Rusty/brown color when first starting pump
    Jun 2015
    Middletown, PA
    1
    Opening my in-ground pool, 18x40. Brought water level up and the pool was clear. Turned on the pump/filter for the first time and a rusty/brown color came out of the returns. any ideas what this may be?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Re: Rusty/brown color when first starting pump
    Hi and welcome.
    First off, can you post your test results? That will help identify what's gone on. -- if you don't have a TFT100 or Taylor k2006 recommended by TFP, see the link in my signature. (these kits can read high FC levels, which is germane to metal oxidization.)
    Is the pool new to you? Are you on a well and had you just added chlorine, by any chance?
    I ask because sometimes people with iron or copper in their water will have it turn brown when they first add chlorine at high levels -- it's from iron oxidizing and there not being enough metal sequestrant in the water, or the metal sequestrant wearing off over winter.
    But if it were only coming out of the returns, I'm not certain what it would be. Do you ave a heater and was it properly drained/winterized? What kind of filter do you have, and if sand, had you backwashed it first?
    What does the water look like now...eg did it mix in just a little, or is the whole pool coffee colored?
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    30,431
    Welcome to the forum.
    Is it still brown? What does your water look like? a pic would likely help.
