Thread: Aqua Rite generating when pump off?
    May 2015
    Clearwater, FL
    4
    I just checked my Aqua Rite generator with the pump off and the green generating light is on. Shouldn't the no flow light be on and the generating light be off when the pump is not on? I have been fighting really high chlorine levels in my pool and I'm wondering if this part of the problem. Is it generating chlorine when the pump is off? Thanks!
    13,600 gal. IG Pebble Sheen, new interior finish Feb 2015, screen enclosure over pool, 2 sheer descent waterfalls, Hayward SWG, cartridge filter, TF 100
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    It should be wired on the same circuit that is turning the pump off so it can't even try to generate chlorine when the pump isn't running. Sounds like the flow switch is bad and it's generating chlorine all the time. That's not good for anyone. They also make hydrogen as part of the process, so you can have a big hydrogen bubble develop. That is not good at all. Remember the Hindenburg?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
