Thread: Should I raise TA?
    April's Avatar
    Apr 2014
    KY
    138
    Should I raise TA?
    All my numbers look good and my ph is staying steady but my TA is 60.
    Should I raise it a little?
    FC-6
    CC-0
    TA-60
    CYA-35
    PH-7.5
    BORATES-50
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: Should I raise TA?
    No real reason to. 60-80 is the recommended range.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Agreed, if PH is steady the leave TA alone.
    April's Avatar
    Apr 2014
    KY
    138
    Thanks
