Thread: New Pool owner, just starting
    May 2015
    Waynesville Ohio
    2
    Hello,
    I just purchased a new house and the previous owner left her above ground Polygroup pool. Same type as an Intex I think...
    It was a pretty nasty mess but I've drained and cleaned it and now am filling it up.
    I'm planning on following the "Guide for seasonal and temporary pools" to maintain the chemicals.
    It says to adjust CYA, then PH, then FC.
    I've got a few questions though...
    1. On this initial fill up, how long should I wait after adding CYA before I adjust the PH and then how long to wait before adjusting FC?
    2. After the initial fill, do I just adjust all chemicals daily and do I just add them all at once?
    3. Are there any specific forms of chemicals I should stay away from for my type of pool? I think I heard just tossing a chlorine puck in can damage the vinyl...
    Thanks for any help.
    Polygroup 3300 Gallon
    AG
    38,475
    Re: New Pool owner, just starting
    Welcome to TFP!!!
    1. Start the CYA dissolving in a sock, then test the pH as soon as you want. Wait 30 minutes, verify your pH and add the bleach.
    2. Daily you will test the pH and FC and adjust as needed. Safe to wait 30 minutes between acid and bleach.
    3. If you are following the temp guide and not using one of the full Recommended Test Kits, you should avoid all chemicals except bleach to raise the FC, muriatic acid to lower the pH or borax to raise the pH.
    May 2015
    Waynesville Ohio
    2
    Welcome to TFP!!!
    Thanks for the quick response.
    So I shouldn't use these HTH chemicals I bought?" PH Plus" which says is sodium carbonate, "PH Minus" sodium bisulfate, and Chlorinating tablets.
    I thought I could just put the tablets in the skimmer basket and the powders in a sock in the skimmer basket.
    It's not safe to do so?
    AG
    38,475
    pH plus is soda ash (cheaper in grocery store)
    pH minus adds sulfates which can build up.
    tablets are trichlor and add stabilizer and chlorine and lower the pH.
    You should not put tablets in the skimmer ... or any chemical really except the sock of stabilizer.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
