Thread: Potential to become corrosive to plaster
    Feb 2015
    Magnolia, TX
    25
    I'm playing around with PoolMath and I'm confused by the warning the CSI field gives: potentially corrosive to plaster. The thing is, I'm entering values all right out of TFP: FC 4, Ph 7.5, TA 70, CH 300, CYA 75, Salt 3000. This gives a CSI of -0.32 and the concerning message. Whats the story? I see that I can easily raise this CSI by raising the Ph but I'm concerned that a higher Ph will lead to calcium scaling on the tile.
    19k inground w/raised spa, Hayward Omnilogic, Tcell-15, Tristar 1.85hp VSP, 250MBtu heater, C4030 filter
    38,475
    Re: Potential to become corrosive to plaster
    Your CSI is within the acceptable range and keeping your pH a little higher would bring the CSI closer to zero.
    One fact you seem to be missing is that calcium scaling will not occur unless the CSI is very positive.
    I will add though, that getting a ring around the tile is nearly inevitable as it is due to water evaporation leaving all the minerals on the tile. Keeping the CSI a little negative can help, but not likely to stop a ring from developing.
