Thread: Replace Pool Deck Carpeting
    Jun 2015
    Manassas, Virginia
    1
    The outdoor carpeting/covering that was on my pool deck has ripped and frayed. I removed it and now all that is there is the bare aluminum. See (sideways) photo.
    I am having a hard time finding someone to come replace the carpeting. In addition, it appears that there are other options like non-skid paint and modular deck tiles such as:
    Buy Patio Tiles and Decking
    Anyone have any thoughts on how I might proceed with this? Obviously the aluminum deck will be tremendously hot so any non-skid paint or deck tiles would need to be heat resistant as well.
    Any assistance would be greatly appreciated.
    Thank you
    11,000 gallon above ground oval pool.
    Hayward pump and sand filter
    Installed 2002
    Filled from well
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,530
    Re: Replace Pool Deck Carpeting
    I would get some of that deck tile stuff in your link. I bet will be last longer and look better than the outdoor carpet. That is just me speaking from my gut.
    Kim
    Oh and I would NOT paint it. It will not stick good for long.
    April's Avatar
    Apr 2014
    KY
    138
    My sister went with the paint and it chipped quickly and looks horrible.
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    If you decide to paint it then use semi-solid or solid exterior stain. It is available in many colors and will last longer than paint, won't chip or peel and is easy to recoat.
    Apr 2016
    Loami, IL
    1
    I am at a standstill with the same issue. What to do? What to do? I see this post was from last summer, what did you end up using and how does it look? Thanks for your help!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by elissamc View Post
    Welcome to TFP,
    You're not likely to get an answer from this poster with them only being here once with this, and not back for some time. I would encourage you to start a new thread with your specifics, and hopefully get some answers.
    Essential Links:
