Thread: New pool
    Jun 2015
    Bessemer,Mi
    42
    New pool
    Hey guys. I have a new 5000 gallon
    Pool
    Intex ultra frame.
    Got the Taylor 2006 kit
    been testing.
    I have 4 ppm FC
    .2 CC
    ph is currently 7.2
    total alkalinty is 110-120
    test turned purple at 100 then red at 110 -120
    i haven't added any borax
    I did add muriatic acid due to ph being 7.8-8.0
    I have a trichlor puck floating around trying to get my
    cya up. Haven't tested it yet. Figure no point.
    Any suggestions or am I doing alright ?
    shoild I raise ph some with borax?
    if so I'm afraid I'll be over the 120 mark for alkalinity
    pool has been running for a week now. Temps are 63-65 right now.
    Thanks for any suggestions.
    Brad from michigan
    38,284
    Re: New pool
    Welcome to TFP!!!
    The trichlor puck is acidic, so I would raise the pH a little bit with borax.
    Do not worry about the TA ... you could almost ignore it completely. Just keep the pH and FC in line. Usually the TA will balance itself out just by keeping the pH in range.
    Jun 2015
    Bessemer,Mi
    42
    Re: New pool
    Ok. Thanks. Sounds good. Appreciate it
