Results 1 to 9 of 9
Thread: Do we really need to level for an above ground pool?
    Jun 2015
    SAINT LOUIS, Mo
    2
    We are thinking about getting an Intex Ultra Frame pool. What will happen if we don't level the ground first? Can we get a gorilla pad instead of doing all the work to level it?
    Thanks for your help!
    Thinking about buying an Intex 18'x48" Ultra Frame
    38,271
    Re: Do we really need to level for an above ground pool?
    Welcome to TFP!!!
    If you do not level, the pool could collapse cause property damage and possible personal injury.
    A gorilla pad is used for cushion on an already level surface.
    Feb 2015
    Bardstown KY
    139
    Do you have to level? Possibly not, if your ground is naturally within 1 inch of level in your pool location. If it's off by more than an inch, then yes, it needs to be leveled.
    27k gallon 33' round, partially buried 22" Sandman sand filter, 1.5hp 2 speed TidalWave pump, Pentair 'Lil Shark with leaf canister, TF-100 Test Kit
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    I tried to setup a small Intex blowup ring pool a few years ago on ground that was out of level 2-3". Let me tell you, it looked scary the amount that the pool leaned. I could not imagine doing this with a framed pool. It would have been even more drastic if it were larger too. Mine was 10 ft at best.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Casey's Avatar
    SW PA
    10,428
    If you decide leveling the pool is too much work, go buy a pool pass for your family.
    May 2015
    Pooler, GA
    311
    Quote Originally Posted by Casey View Post
    Yay to swimming in a pool that uses urine as a sanitizing agent and hair gel as a stabilizer!
    TF-100
    Helpful Links
    domct203's Avatar
    Jun 2015
    CT
    3,578
    Quote Originally Posted by downtownbrown View Post
    The installation sight needs to be level w/in 1" or better as mentioned.
    Look at it this way, an 18' x 52" Ultra Frame, filled to 48" as recommended will be about 7600 gallons. ONE (1) gallon of water weighs 8.34 lbs.
    8.34 X 7600 = 63,384 lbs. or 31.7 ton.
    If the ground is out of level, you pretty much have a half-loaded tractor-trailer on a hill, held back with a vinyl pool liner.
    Make it as level as you can.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,455
    I set up a couple of small, blow up kiddie pools for my Kindergarteners on what looked like level grass.
    WELLLLLLL let me tell you something--------one of the spots was not so level. When I filled the pool up it leaned towards the low side! I could not let the kids use that pool as I was sure it would tip over with kids in it.
    THAT was with a small wading pool. Maybe knee height. I would NOT take the chance with it!
    Kim
    Casey's Avatar
    SW PA
    10,428
    Quote Originally Posted by Scuba_Steve View Post
    Some people just don't care n need the simplest solution for their lifestyle.
