Thread: CYA didn't increase?
    May 2015
    Midlothian, Texas
    18
    Being that I decided to continue with SWG and am waiting for the new cell to arrive, I wanted to get my CYA up from ~50-55 to ~70-80 in preparation. I added 4lbs of pre-dissolved cyanuric granuals 5 days ago and have run constantly since, but testing still shows the same reading. No water loss, FC holding as expected around 6 with loss of about 2 a day, no CC, PH high today from a lot of use/kids in it all day yesterday, TA 90. Any idea why it wouldn't have raised as expected?
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: CYA didn't increase?
    How are you testing? What do you mean by "pre-dissolved"? Did you do this in a bucket or something, or use liquid CYA? How many gallons is your pool?
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    May 2015
    Midlothian, Texas
    18
    Yes, in a bucket with pool water, then into skimmers a little at a time. 22k gunite. Testing with TF 100 kit.
    38,324
    Well,
    1. you are not sure when it is all truly dissolved in the filter. It would not have dissolved much in the bucket ... really made a slurry I would think.
    2. Testing error? Were both tests done in the same lighting conditions? The test is +/- 15ppm, but if conditions were the same, I would have expected you to see at least some rise.
    May 2015
    Midlothian, Texas
    18
    Yes, mostly a slurry, but would hope a few full days of pump running would dissolve it. Testing done in same light and as exact as possible with this kit....maybe my eyesight has gotten better during the week I'll just give it a little longer and see what it does.
    May 2015
    Pooler, GA
    311
    Next time add the CYA to a sock and place it either in front of a return or in the skimmer. (return preferred)
    You added an unknown variable by doing the bucket method. It still should have risen, so your guess is as good as mine...
    TF-100
    Helpful Links
