Thread: How to read TF 100 test results
    Jun 2015
    Pittsburgh, PA
    13
    I have two questions...
    TA Test... Am I looking for a really red color? Like blood red? A dark pink? Just as the water starts turning redish pink?
    CYA Test... Should the black dot be COMPLETELY disappeared? I shouldn't even have the faintest trace of a black dot?
    Thanks in advance!!
    19,500 gallon, 33 above ground, Vinyl liner. Chlorine
    Pump: 1.5 HP 2-Speed 3450/1725 RPM, 115 volts Above Ground Pool Pump - Waterway brand
    Filter: Waterway Clear water II Cartridge Filter
    Heater: Hayward H150FDN Low NOx Natural Gas Heater
    Test: TF-100 test kit w/ SpeedStir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: How to read TF 100 test results
    For TA, you are looking for color change. Keep adding drops 1 at a time until teh last drop does not produce any change at all. Then dont count that last drop.
    CYA, the black dot needs to completely disappear.
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    The red is more like Barbie Pink. And the CYA test means you don't know there's a dot in the tube. Look away a second and then look back. Pour the sample back into the mixing bottle and repeat it as many times as you need to feel comfortable with your readings. If you're always getting something between, say, 40 and 50, call it 50 and be done with it.
    Check the video instructions, too. https://www.youtube.com/user/TF100TestKit/videos
