Results 1 to 7 of 7
Thread: Which Stenner to Buy
    May 2015
    Chandler
    107
    OK, I'm going to get one of the stenner pumps to automate my chlorine. I am looking at 3gpd, 10gpd, 22gpd...the cost is the same at 208. Which one should I get? I understand the math of how many minutes to run each one but what are the adv and disadv to each? Thank you.
    14,000 gallon pool, plaster, Pentair FNS 60 DE, Variable speed pump, Chandler, AZ (Phoenix area)
    22,550
    Re: Which Stenner to Buy
    Are those fixed models?
    Are you planning on running it on a separate timer?
    With your pool being 14,000 gallons, 3gpd pump is plenty large enough. However, I suggest getting the 10gpd model. It gives you more flexibility in run time.
    Apr 2013
    North OKC Area
    300
    Where do you find thrm for $208?
    May 2015
    Chandler
    107
    Bama, yes fixed. Thanks for the recommendation. I need about half a gallon a day during summer in PHX so that means about 70 minutes or so on a 10gpd pump.
    Daniel, here's the link. I was wrong it's 202, even better.
    Single head - Fixed Rate Low Pressure
    May 2015
    Chandler
    107
    I was wrong again, sorry. The link I gave you was low pressure. Here's the hp for 208.
    Single head - Fixed Rate High Pressure
    Apr 2013
    North OKC Area
    300
    Thanks, I will have to get one before next vacation. I'm on vacation now worrying about my pool.
    May 2015
    Chandler
    107
    I'm leaving tomorrow morning. Same story.
