Thread: I bought a new house and the pool leaks. Please Help!
    Jun 2015
    Bedford hills ny
    46
    Hello all.
    I bought a new home that has an old gunite pool (at least 10 years old... Maybe 50, I have no clue).
    We tried to fill the pool but it would get 2/3rds full then it leaked as fast as we could fill it. Once we took the hose out it maintained that level.
    I decided to drain, clean/scrub out the pool and noticed a few things.
    1) there is a caulked joint around the bottom of the pool where the sides meet the bottom
    2) there appears to be a crack in the pool
    3) the pool appeared to fil to the level of a light that was clearly leaking but struggled to pass it
    i am trying to replace and re-seal the light
    what is the joint? Should I replace it? It appears there is either caulk or epoxy on top of older caulking? Should I replace all of it? In some areas the caulked area appears wide (1.5" instead of 1/2") should I patch that?
    should I treat the crack as a problem?
    should I do all three or one at a time? I have gone to the problem of creating a clean dry pool.... Should I attack all three?
    thank you
    20' x 50' AG gunite pool (no idea on gallons) built a long time ago. DE Filter w/Hayward Pump. Well water.
    Jun 2015
    Bedford hills ny
    46
    Re: I bought a new house and the pool leaks. Please Help!
    Here he is the pool
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I am not sure but I know we need some pictures, it will give a visual of what you are asking about
    here is 1 way to do it..
    Posting Photo's Tutorial
    you can also use imgur Imgur
    Get Started Imgur help
    you beat me to it
    Jun 2015
    Bedford hills ny
    46
    Here is the leak (I think)
    Jun 2015
    Bedford hills ny
    46
    Here is the caulk / epoxy
    Jun 2015
    Bedford hills ny
    46
    I am putting better pictures up
