Thread: Spa heating issue
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Spa heating issue
    Hey guys...
    I have a spill over spa in my inground pool.
    I use an old heater that always worked great for the pool. The pb put the spa in, and it works excellent. Jets work great, spills over perfectly... No complaints.
    My only complaint is that the old heater starts cutting off when the spa reaches 100 degrees. It might get to 101, but never any hoter. This is not a digital heater. I just turn the spa on, and turn the heater all the way up. Within about 20 minutes, the spa is 100 - 101.
    Is there any way to play with the thermostat in old style heaters to make it stay on a little longer? It I could just pull another 2 or 3 degrees out of the thing, it would be perfect.
    I really can't afford to spend over 1k on a new heater right now.
    any advice would be greatly appreciated!!!
    Thanks in advance,
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Spa heating issue
    Mitch, I don't have an answer, but I can tell you the folks who can help will need to know at least the brand and possibly the model of the heater to really answer your question. Good luck.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Yeah, a make and model would be handy. If it's an old millivolt heater I'd suggest just trying a new temp sensor/thermostat assembly.
    And if you decide to do that there's no reason not to make a science experiment of the old one. It may be as simple as putting a resistor on the temp sensor line. But that brings us back to needing to know what kind of heater you have.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Thanks a million guys. I will post the make / model of the heater when I get home.
    I know it is a Minimax, but off hand I have no idea what the exact model is.
