Thread: Hayward Sence and Dispense
    May 2015
    Bellingham,Washington
    2
    I have had this Co2 ph system for several years and it worked fine. A 20 # Co2 bottle would last for months. It now has started to just dump the whole bottle when turned on. Is this the falt of the software or does the dispenser unit at fault?
    34,000 gallon in ground pool
    550 gallon in ground spa
    Hayward Pro Logic AQL-PS-16
    Total Pool Chemistry
    T Cell 15 salt chlorination
    38,532
    Re: Hayward Sence and Dispense
    Welcome to TFP!!!
    Sorry you have not gotten any quicker responses, but I do not think very many members have the S&D let alone a CO2 bottle.
    Seems like you need to figure out if the valve is leaking or if the system is opening the valve inadvertently.
    May 2015
    2
    Thanks, I think it is a problem with the valve. I have liked this system except I would still have to add acid to keep the TA down so it doesn't solve the Ph control completely. I may just resort to just hand adding acid if needed. Replacing this valve is expensive.
    38,532
    I think if I went with a system like this, from what I have read it is less expensive to use an acid feeder than dealing with the CO2 tank. But I have no idea what the cost of switch over would be.
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    To switch over to an acid tank and a stanner pump would be about $500. Hayward AQL-CHEM3-240 Sense and Dispense pH Dispense, 240V, Acid Feed
