Results 1 to 9 of 9
Thread: Test Results
    Jan 2015
    Puyallup, WA
    50
    Test Results
    Rookie results.....
    Chorline = 5
    PH = 7.8
    CYA = 50
    TA = 70
    CH= 25 --- way low when I tested on Friday I was in the high 200's
    Not sure how to post these scores so I listed out each one
    FC = 8
    CC = 0
    TC =8
    20x10 Intex Pool
    Sand Filter SF15110, Solar Cover
    TF-100
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Re: Test Results
    Good job!
    Your PH is a little high. Use muratic acid to bring it down to 7.5. Use pool math to know how much to add.
    CH----How did it get from 200 to 25? If you did not do anything to the water please check your testing to see if you might have made a mistake. BUT with your having a vinyl liner your CH really does not matter.
    You list chlorine as 5 in the top set then list FC=8 can you please tell me how you got these results.
    You did a great job with the posting!
    Kim
    Jan 2015
    Puyallup, WA
    50
    Re: Test Results
    So when I did the chorline and PH test the yellow side was reading 5. Does that make sense?
    20x10 Intex Pool
    TF-100
    Jul 2012
    Tallahassee, FL
    30,444
    Re: Test Results
    That does ma sense BUT how did you get your FC ?
    Trying to make sure I know what you are doing before we go any further.
    Kim
    Jan 2015
    Puyallup, WA
    50
    Re: Test Results
    Following the procedures on the tf-100 test kit.
    20x10 Intex Pool
    TF-100
    38,271
    Re: Test Results
    The yellow OTO chlorine test is a good indicator of no chlorine vs chlorine in the water, it is hard to tell from the color what the FC level is. The FAS-DPD powder chlorine test is much more accurate.
    Jul 2012
    Tallahassee, FL
    30,444
    Re: Test Results
    Okay so you are doing two tests for Chlorine/FC. Got it now.
    There is no need. I just use the powder test due to how accurate it is.
    When you post your test results please just do and post the powder test. If you want to use the yellow test for your every day test you can. Just know it is like stated above---------is there chlorine in the water is all it really shows.
    Kim
    38,271
    Re: Test Results
    FYI, I always do the OTO test when I do the pH .. and then follow up with the FAS-DPD to get the real FC number. I like to see how close of a guess I can get ... and I seem to get remarkably close
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: Test Results
    In the few weeks I have owned my pool. I have used the OTO test twice...
    It is pointless in my opinion.
    The only purpose it serves is the FAS-DPD test can give a false reading and tell you that you have 0 chlorine under certain circumstances. The OTO test will show you that this is a false reading. I believe this only happens at a very high level of chlorine, although I could be remembering wrong.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
