Results 1 to 7 of 7
Thread: new in pool steps sand issue
    May 2015
    eden,ny
    2
    i have , in its second year,a 24 foot doughboy, 52 inches deep above ground.i have the curve in pool step system.the directions told us to fill the Side walls with sand for weight.there are two plugged holes on each side chamber which we funnelled a bunch of sand into. the steps stayed down in the pool all year.however i started noticing small clusters of san in the bottom of the pool.this spring with the steps out i noticed there was a small open hole at the top of each sand chamber where i assume the sand was trickling out.i tried to flush out all the sand and just fill the chambers with water but the steps keep wanting to float up. can i use pea gravel in these chambers and if so how much do you suggest.can i fill the chambers with quickrete and mix with water to harden it.i can plug the two open holes so the gravel has no chance to get out.i just would like an altrnative to using sand. thank you ,paul
    i wanted to post a pic of the steps but was unable to through your manage attachments link.i shrunk the jpeg down to 32 kb ,it appears to upload yet there is an exclaimation point next to the file and no thumbnail to put a checkmark in to select that image . there is just an old existing image that i can choose from an unrelated post .that image is 82 kb and it says i have up to 250kb so my new thumbnail shouldnt be to large a file.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,580
    Re: new in pool steps sand issue
    You can use photobucket to post pics. It works great.
    Steps-if you fill them with concert will you be able to get them into and out of the pool?
    Steps are the biggest algae hiders in an AGP so it is very important you can get them out to clean them. Some people make weights to hold them down with out of pvc pipe and cement.
    I will wait for pics before saying what I think will work best.
    Kim
    Casey's Avatar
    SW PA
    10,453
    You have no idea how heavy those are going to be to get out come closing. I got rid of the sand in mine because it still floated. I filled 6 bleach jugs with sand n water n attached with bungee cords.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by Casey View Post
    Great reuse of bleach bottles
    Orlando, FL
    690
    I use a 10 lb weight and a brick that I covered with plastic to prevent accidentally damaging the liner. The bleach bottle idea is also a good one but the steps came along after I stopped buying bleach.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Casey's Avatar
    SW PA
    10,453
    This works so well for me. Steps don't float either.
    Jul 2012
    Tallahassee, FL
    30,580
    You could use any plastic jug like laundry detergent or such.
    Kim
