Thread: Cannot edit my signature
    geri's Avatar
    Sep 2009
    San Rafael California
    16
    I created a signature a few years ago and today I attempted to make a very minor change without success. No matter what I try to do, even if I attempt to re-save my current signature I get the following error message: Your signature contains too many lines and must be shortened. You may only have up to 5 line(s). Long text may have been implicitly wrapped, causing it to be counted as multiple lines. BTW I get this message no matter what I do, even if I try to pare the signature down to a single word or eliminate it entirely! I am at a loss. Any ideas?
    18.5K Gallon, "L" Shaped, IG White Plaster Built 1967,Re-plastered 2001;Transitioning from Old School equipment: 1 1/2 Copper and plastic plumping, Pentail Intelliflo VS pump (2013), Tagelus TA-60D with Clear Pro (2012), Teledyne "One" EPC 325,000 Btu NG Heater (1992), Aquabot 4wd cleaner.[On Hiatus:1/2 Hp Sta-rite Booster pump (1993) with Jandy Ray-Vac (2001)] In our care since December 2008, using BBB method since June 2009.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Cannot edit my signature
    Hi Geri,
    it might be due to the software upgrade a bit over a year ago. I will alert an admin about it for you.
    Divin Dave,
    mas985's Avatar
    Pleasanton, CA
    11,737
    I have had this problem as well. Even though you think you have 5 lines or less, which is the limit for signatures, the forum software wraps the text at a certain width and creates another line during the validation process. Basically your signature is too long and you have reduce the number of lines or the number of words per line. There is also a 800 character limit and I found out the software counts the characters in any URLs that are hidden.
    Looking at your signature, there are probably a lot of words you could eliminate without losing much information.
    Mark
    geri's Avatar
    Sep 2009
    16
    Looks like it may be fixed now. Will try again to make changes
