Results 1 to 9 of 9
Thread: Confused regarding to the chemicals.
    Jun 2015
    belleville mi
    7
    I performed a test using a TF 100 kit.
    TC 10
    FC 8.5
    PH 7.5
    TA116
    CH 125
    CYA 0
    CC 1.5
    Please assist me in what I need to purchase in order to get the pool accurate. The pool is 24 foot round and carries 13500 gallons.
    Thank you
    30,432
    Re: Confused regarding to the chemicals.
    Welcome to the forum.
    Your test results indicate you MAY need to SLAM your pool. (nice work on doing your first tests....looks like you did them correctly)
    Have you read the SLAM article?
    What does your water look like?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Are you saying your CC is 1.5? Anything over one AFTER a party would concern me. Mine will generally burn off up to 1 CC on a good hot day.
    Jun 2015
    belleville mi
    7
    water look clear with just a little cloudy , should I add stabilizer
    30,432
    Yes, add enough stabilizer to get to 30 ppm
    Donldson's Avatar
    NW Ohio
    2,917
    Welcome to TFP and congrats on a successful first test!
    One thing you will have to get used to with TFP is there is no "clear but a little cloudy". If it is a little cloudy then something is not right, and your CC reading backs that up. So I will back up duraleigh, you want to get your stabilizer up (to help buffer the chlorine and protect it from sunlight) and then perform a SLAM - Shock Level And Maintain to get rid of anything that is lurking beneath. It is a fairly simple process and will clear up the cloudiness. Trust me, I know from experience that "clear" means one thing before TFP and a completely different thing after you join. I like the new definition of "clear"!
    PS: it would help us a lot if you can edit your signature to add your pool information. That way we will always see it if you need help in the future and don't have to ask you for it.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2015
    belleville mi
    7
    Thanks going to add stabilizer and read the slam article , the pool was full of debris and green , spend the last 2 weeks cleaning ,got it to this point then I found this site . The pool store is killing me in cost after a day my chlorine would disappear that's when I knew I had a problem .
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Quote Originally Posted by kwall View Post
    well, we would suggest not going to the pool store. Their objective is to sell you as much stuff as they can.
    Stabilizer & bleach you get at WalMart
    Muratic acid at Lowes or Home Depot.
    When you add that stabilizer don't just toss it in the pool measure the amount you need (use pool math link above) and put it in an old sock and hang it in front of one of the returns while it dissolves.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    The bloodsuckers won't get any more of your money now that you have your own test kit! That kit will have paid for itself by Fourth of July, I'll bet.
    Keep your eyes peeled for deals on "Liquid pool shock" this time of year. It's usually 10 or 12% and it's usually fresh.
