Thread: High CH
    Jun 2015
    Missouri
    4
    High CH
    How can I lower the CH in a plaster pool ?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: High CH
    Welcome to TFP Bronco!
    You can only change it by adding water with less CH in it. You have to remove the old and replace with the new. As water evaporates, it leaves CH behind, so it builds up over time when you add hard water. A form of Chlorine (Calcium Hypochlorite) can also add CH to the water, so be aware of that.
    What is your CH level now?
    Essential Links:
