Results 1 to 8 of 8
Thread: Aqua Trol cell reading 26.5 volts / 4.57 amps
    May 2015
    Lafayette, La
    7
    Instructions say max is 26 volts and cell amps 4.0
    Showing 3300 ppm
    Any thoughts?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Aqua Trol cell reading 26.5 volts / 4.57 amps
    This is what I found in the manual.
    2. Cell voltage (typically 22.0 to 26.0 volts when chlorine is being generated, otherwise 30-35V)
    3.Cell current (typically 2.50 to 4.00 amps when chlorine is being generated, otherwise 0 amps)
    I think that's close enough not to worry about.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2015
    Lafayette, La
    7
    I don't think more amps is better..I have found other info saying volts can vary to a max of 28 but so much info on the web and am reading what the manual says as well.
    32 x 16 Doughboy Desert Spring 2 ft in the ground, Hayward S210T93S Pro Series 1-1/2 Hp pump , Fairmount sand , Aqua Trol SWG, Morton salt
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Usually a higher salt level would cause the amps to go up. You are at the higher end of the salt according to the manual, but I don't think it's too high as it will shut off if it gets too high.
    Last edited by n240sxguy; 06-07-2015 at 09:54 AM. Reason: Actually the manual says 3400 ppm salt, so I don't think the 3300 is too high.
    May 2015
    Lafayette, La
    7
    The amperage has dropped down to 4.08 with all the rain we have had , now my level is 3100 , @ 80% output.. Brought water to Leslie's and all it needed was 20oz of muratic and 4lbs conditioner..
    I know I paid more for the conditioner ($28) but not owning a pool before I learned alot yesterday and the woman was really cool and like the fact I got a print out and she said come as often as you like ,even if I don't buy anything..
    Couldn't work in that store , I smelled like chlorine after I left
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    If you read just about all threads on this forums there is a common theme - "Get your own good test kit"! Do not rely on pool store testing. It may be "free" but, is it accurate? Does the employee know what their doing? They are in business to sell you chemicals etc. at very jacked up prices. You can see the recommended test kits at:
    TFTestkits.net
    You can get the Taylor K-2006 kit at many pool stores. The TF-100 give you the most bang for your buck. When you get your kit, you can post your numbers and get excellent advice as to what you need to do and where you can get the chemical(s) at cheaper prices then a pool store.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    The Aqua Trol uses the GLX-CELL-5 salt cell. The numbers are OK. What is your water temperature?
    Do you have the T-5 cell?
    Note that high water temperature will cause higher than normal amps. This is increased further if the cell is after a running heater. For a high temp pool with a heater, you want to maintain the salt at the lower end of the range to prevent a high amps error shutdown.
    Support the site
    May 2015
    Lafayette, La
    7
    T-5 cell , water temp was 89/90 today..
    As for doing my own water testing I have the strips and after doing what was said 20 oz muratic which I have , and 4 lbs conditioner , spot on.. yeah I know I paid more for the CYA
    New to this , running 70% for 8 hours took a splash this afternoon , really nice , no smell ,eyes feel great , just a slight taste of salt at 3100..
    Tested before I left this evening with strips, everything is spot on.
    I will see about getting a good test kit , big learning curve to me ..
