Thread: How preccisely do you meeasure bleach?
    Apr 2015
    Tyler TX
    27
    Trying to figure out just how precisely I have to measure when adding bleach according to Pool Math. For example, PoolMath says I need to add 172 oz and I have 121-oz bottles and 64 oz bottles. Can I just add one 121-oz bottle and guesstimate how much I need from a 64-oz bottle to reach 172 oz? or do I need to use a measuring cup to measure precisely? Is there some other short cut?
    Thanks!
    Carolyn
    Tyler TX
    13,500 gal IG plaster Saltwater Pool
    Jandy Aqualink RS, Jandy cartridge filters, Jandy Stealth series pump
    Polaris 280, TF-100 test kit
    rdw1961's Avatar
    May 2012
    Mount Pleasant, PA
    17
    Re: How preccisely do you meeasure bleach?
    I just use a 64 oz water pitcher with marking every 8 oz. If I need 20 oz of bleach I fill it half way between the 16 and 24 oz markings. Close enough for Government Work for me.
    24' Above Ground Round vinyl
    DE Filter pump 1HP
    Flow Rate 39GPM
    14700 gallon
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Many owners do exactly what you are doing. I took a 30 oz bottle and put marks on the side at at 8, 16, 24 & 30 oz. it gets me close enough if I have to add bleach.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    I use a clear plastic measuring cup.
    Works for me. I add around 32oz of bleach every day.
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    30,405
    Let common sense and pool size dictate your need for accuracy.
    Certainly you can be pretty liberal in a VERY large pool and need to be more precise in a small pool.
    The FC test teach is done in .5 ppm, you can use pool math and figure out just how much that will be in your particular pool and use that as a guideline. There is no sense in being more precise than you can measure.
