Thread: Reuse K2006 reagents for TF-100?
    Jul 2014
    NJ
    123
    My refill is on order for the TF-100.
    Is there any chance I can use some of the reagents in the Taylor K-2006 for TF-100 tests?
    I am in the middle of a SLAM and I am getting dangerously low out of R-0871 for the FC test. Probably not, but I figured I would ask.
    20x40 L-shape 35k gallons, Pentair FNS 60 SQFT DE Filter, Pentair Multi-port Valve, Hayward Super Pump w/1 glorious HP, Vinyl Liner, Dolphin Z5, TF-100 w/Speed Stir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Reuse K2006 reagents for TF-100?
    You can't use the Phenol Red for the TF100, but the Chlorine reagents are no problem. If the numbers match, you can use them.
    Essential Links:
