Thread: Cleaning water line stains
    I have not one but two nasty brown water line stains on my lines from the swamp water the previous owners blessed me with .. one is above the water line, the other below it. Are there any good methods to remove thsese outside hours of scrubbing? The brush seems to get some of it but there is some tougher discoloration that just won't go away.
    To help you out, we need to know what type of pool you have... fiberglass? plaster w/ tile? vinyl?
    8000 gallon 20' x 48" round vinyl frame pool, 12" sand filter (don't have the specs on the pump), TF100 test kit
    Handy Links: PoolMath, TF-100 Test Kit, Pool School, CYA-Chlorine Chart
    It's a AG with a vinyl liner
    Mar 2007
    Richmond, Va
    We've got something called "wipeout" that seems to take that line away.
    also we added a scumbug to the skimmer and is soaking up lots of black gunk.
    ah em, got both at the pool store
    18 ft.52" Round Atrium AG -7600 gallons, Sand Filter, Vinyl liner, Royal Entrance Steps, 80 lbs.solarsalt
    mbar's Avatar
    Ashland PA
    Try a Mr. Clean Magic Eraser - it works
    16x33 fiberglass pool sand filter
    Mar 2007
    Coastalish 'down easter'
    Baking soda or pH+ on a green kitchen scrubbie will also do the job.
    Luv& Luk
