Thread: Caretaker Rebuild Problem
    Jun 2015
    Vero Beach, FL
    3
    I've rebuilt the 5-port valves using the Jandy's OEM rebuild kit. Everything seemingly went together smoothly but when I started the system back-up a loud rattling sound occurred. It sounded like one of the ball bearings was spinning around inside the top housing. I've since taken it apart twice in an attempt to locate the problem -- without success. All of the internal parts appear to be in their correct positions. The pistons stay seated when I turn the center plate over. The cam assembly impeller and gears spin freely and all 5 of the ball bearings are seated in their indents. There is no rattle when I manually spin the impeller.
    Disassembling and reassembling the unit three times is about as much punishment as I can take; frankly, I'm at my wits end; . I've contacted three local pool service companies and they don't see to want to touch it. HELP !!!
    Frustrated in Vero Beach, Fl
    Our pool is approx. 10,000 gal. gunite with spa. It is a chlorine based system with: heat pump, two 1.5 hp circulation pumps, and 5 port in-floor Caretaker system.
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Re: Caretaker Rebuild Problem
    I don't work on these parts at all but thought maybe I could provide you some guidance. Have you done a YouTube search for videos on repairing these systems? If you have then my apologies.
    How to Replace a Caretaker 99 In-floor Cleaning System - YouTube
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Jun 2015
    Vero Beach, FL
    3
    Thanks, Paul, for trying. I have watched the videos. In fact, they got me through the rebuild. Of course when they show how to do it everything ends-up working perfectly at the end.
    Ray
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    Quote Originally Posted by Ray1776 View Post
    Ray
    I am in exactly the same situation right now.
    I have rebuilt it several times and I am about done with this thing.
    Did you ever resolve the issue and can you share some of your wisdom to this poor soul?
    Thanks!
    Migoni
    20,000 Gallon in-ground PebbleTec pool, 1.5 HP Pump, Pentair Quad DE-80 filter, In-Floor Cleaning CareTaker, city water, K-2005 test kit.
    My Real Helmet assemble, paint and collect
    Sep 2017
    Silicon Valley, CA
    296
    Not sure which part of the OP's old post you are experiencing. If you are getting the loud rattling, the thing that causes that in my Caretaker is air in the line. I've also heard this described as kind of a water hammer effect. I get it every time after I've opened up my system for some maintenance as simple as cleaning out the pump basket.
    To resolve it, before I open things up I make sure the diverter to the Caretaker is completely closed. After the pump is primed and air is purged from the filter, etc, I start bleeding the water supply back to the Caretaker by throttling the diverter to it a little open, till it starts a small rattle in the Caretaker, and then close it. I repeat this multiple times for a few minutes, slowly getting the Caretaker filled up with water only. At least, that's what I think is happening inside there. Anyway, this method works for me.
    One other thing that may cause the rattle is too low water flow over a prolonged period. I am in the early stages of observing this while I've been experimenting with lower pump rpms, so I'm not positive about the causal effect, but just thought I'd mention it in case you've made recent reductions to your pump speed with the Caretaker open to flow for extended periods.
    18Kgal play pool+spillover spa, Tahoe Blue Quartzscape refurb June 2017, ~40'x15'
    1.5HP VS JeP, CCP420 cartridge filter, Sta-Rite 400HD, 1.0HP VS JeP for sheer descents
    Caretaker in-floor system, AP1400 SWCG, Aqualink: RS-8 Combo, iQ20, One-Touch
    K-1005, K-1515 FAS-DPD, SpeedStir!, digital pH meter, 9056 comp block
