Results 1 to 8 of 8
Thread: Water little bit Cloudy
    Jan 2015
    Puyallup, WA
    50
    Today was the true test for the pool. Had lots of folks adults and kids it was a good time. But as everyone was done the water in the pool seem a bit cloudy and it hasn't been like this before. What causes this and what test should I run to fix it. It isn't so bad that we can't see the bottom of the pool but it's not like it was yesterday.
    Thanks!!
    Casey's Avatar
    SW PA
    10,422
    Re: Water little bit Cloudy
    Please update your signature with you pool info so we don't have to continually ask for it every time you post.
    Also, if you have one of the recommended kits, you need to run a full set of numbers and post them. You more than likely have zero chlorine in the pool.
    For future heavy bather loads, you should bump your FC up 3-5 ppm more than your normal to carry you through the chlorine demand.
    Jan 2015
    Puyallup, WA
    50
    Will post numbers shortly.
    20x10 Intex Pool
    Sand Filter SF15110, Solar Cover
    TF-100
    Jan 2015
    Puyallup, WA
    50
    Here are my results:
    Chorline = 5
    PH = 7.8
    CYA = 50
    TA = 70
    CH= 25 --- way low when I tested on Friday I was in the high 200's
    Not sure how to post these scores so I listed out each one
    FC = 8
    CC = 0
    TC =8
    20x10 Intex Pool
    TF-100
    Casey's Avatar
    SW PA
    10,422
    Don't worry about CH. run. Higher FC level and your filter for a few days and it should clear right up.,
    Jan 2015
    Puyallup, WA
    50
    Thank you Casey. What do you mean higher fc level and your filter should clear it up?
    My chorline was low last night when I tested before going to bed so I added bleach and it appears that is helping as well.
    20x10 Intex Pool
    TF-100
    Casey's Avatar
    SW PA
    10,422
    That's what I mean. If your usual FC is 5, run it at 8 til it clears and run your filter 24/7 until it's clear which should not be long.
    Jan 2015
    Puyallup, WA
    50
    Thank you Casey for your help!
    20x10 Intex Pool
    TF-100
