Results 1 to 9 of 9
Thread: pool opening questions
    When the pool was closed antifreeze was used I have 2 jets and the only way i can drain is via skimmer./filter. So how do i get the antifreeze out so that it doesnt go into the pool?
    also i see different info on how high to get FC to. Is it 3ppm or 10 ppm on opening and how many times do i need to reach this level and what time duration
    thx
    18x38 IG
    Appox. 85000litres
    Jacuzzi laser sand filter
    1hp pump
    Municipal water
    Jan 2012
    'burbs of Augusta, Georgia
    7,254
    Re: pool opening questions
    Quote Originally Posted by wantboost View Post
    thx
    Can't help you on the antifreeze question as we don't close our pool, sorry! But the answer to your chlorine question is: the correct answer is based on your pool's CYA level and how your water looks, and what your own reliable testing shows for chemistry levels.
    What's recommend fc for pool opening
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    Jan 2012
    7,254
    There is no "One size fits All" amount. Every pool has its own needs based on CYA, sun exposure, water quality, water tests....
    How do you test your pool water? How does your pool look? How do you chlorinate your pool?
    Ok I ll use the chart that compares cya / fc. But if I need to get into the target range or shock range for opening? And how many times if I need to get I to shock range should I get into that range in a 24 or 48 hours period?
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    SLAM .... Shock Level AND MAINTAIN .... so you want to get above shock level and keep it there until your water clears. You can go a bit above and then refresh before it gets down to shock level.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Once it clears then start balancing all other chemicals??
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    When slaming.is there a need to add algeacide
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    There is never any need for algaecide. Liquid chlorine during your SLAM will kill whatever algae you have, and maintain a proper FC level will keep it from returning.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
