Results 1 to 9 of 9
Thread: First Taylor K2006 test results...
    Can anyone tell me what I need to do please? I figured out that I need to add 3 oz of bleach according to pool math, after that I am a little lost.
    3.4 FC
    .4 CC
    7.6 PH
    150 TA
    160 CH
    35 CYA
    Thanks in advance!!!
    Michelle
    Intex Ultra Frame 14' x 42" (3,357 gallons)
    1,000 GPH cartridge filter pump
    Taylor K2006 Complete FAS-DPD
    Donldson's Avatar
    NW Ohio
    2,881
    Re: First Taylor K2006 test results...
    Congratulations on the kit!
    Your numbers look just fine. A little bleach will make sure you don't go below minimum between now and tomorrow. Figure your FC target based on a 40 CYA, best to always round up.
    Going forward you can just use the 10 ml sample for your chlorine test. It saves reagent and the 0.5 ppm precision is fine for all but the most unusual situations.
    Tomorrow you will want to test your pH and chlorine. Your CH, TA, and CYA are more weekly-ish tests than daily. After a while, once you get the hang of things and get a feel for your pools chlorine appetite you will be able to just do the yellow OTO chlorine test daily and save the pink FAS/DPD test for every couple of days.
    So now, enjoy your pool!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Those numbers look good. Continue keeping FC between 3 and 7 ppm.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Um.... go swimming? Those numbers are fine. For now.
    You need a bit more bleach than that. With 35 CYA, pool math says 3 to 7 FC as the target. What that means in real terms is never let FC drop below 3 and aim high enough that it won't drop below 3 before the next time you add bleach. Could be 5, could be 6, could be 7. Every pool is slightly different. You'll learn quick enough through daily testing how much your pool eats every day. I'd say target 6. That's 13 ounces of 8.25% clorox.
    Now... on to confuse you a bit. Taylor says to use 25 ml of water and 2 scoops of powder. Well of course they would, the same way coffee roasters tell you to use massive quantities of grounds when you brew a pot. You can use 10 ml of water and only one scoop of powder. As long as there is still one or two undissolved granules after you swirl it, you have enough powder. Then when you count drops, each drop is .5 FC. It saves time and expensive reagents and is plenty accurate for our purposes.
    Thank you all! You are SO helpful!
    Michelle
    Donldson's Avatar
    NW Ohio
    2,881
    Didn't know that the k-2006 only had those instructions. So yeah, when I said use a 10 ml sample, I mean do what Richard said. Most instructions around here come down to "Listen to what Richard said"
    Quote Originally Posted by Donldson View Post
    LOL ok good to know!
    Michelle
    KineKilla's Avatar
    May 2015
    West Jordan, UTAH
    53
    My Taylor kit says to use 10ml of water and 2 scoops of powder. You saying 1 scoop is just as good?
    Polar Pools, 19' x 39' Vinyl Lined IG, 3' to 9' deep, 33,300 Gallons?
    Pentair Intelliflo VS, Hayward Sand Filter Model # S244T, Compupool SWG, Heliocol Solar Heating
    K-2006 test kit, 1766 Salt Test Kit , Taylor SpeedStir
    Built in 2009, Salt Lake City, UT.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Yep. One scoop is plenty. Like Richard said, as long as there are a couple undissolved granules in the bottom you know you used enough.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
