Thread: Pressure going from 15 psi to 25 after vacuming for 5 min. ??
    Jun 2015
    Vancouver
    18
    How long does it usually take for a dirty pools water pressure to rise while you are vacuming ? Mine went from 15 to 25 in 5 minutes. And its done this a few times. The water coming from the outlet ports sometimes looks dirty too.
    I have a main thread with some of my other problems here related to this here http://www.troublefreepool.com/threa...y-pool-outlets
    Thanks guys.
    Oct 2014
    Sacramento, CA
    72
    Re: Pressure going from 15 psi to 25 after vacuming for 5 min. ??
    If you have dirty water returning from your returns then more then likely you have a cracked filter manifold or a tear in the filters also how much dirty are you vacuuming each time sounds like you may need to replace your filter elements
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    Jun 2015
    Ramsey, NJ
    3
    Quote Originally Posted by SacPoolPros View Post
    Same problem occurred with mine. Torn filter manifold. I bought a replacement and changed it.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    My experience, with both Pentair and Hayward sand filters, is that vacuuming an extremely dirty pool can result in dirt bypassing the sand. Very frequent backwashing may be required.
